Page 2 of 9 FirstFirst 1 2 3 4 ... LastLast
Results 16 to 30 of 121
Thread: Sudco manifold and Mikuni carb
    Nov 2008
    MI
    141
    ATC 90 Front Suspension
    I am making a US90 hot rod conversion. I have a modded engine in a stock US90. I am not eliminating an early US90 from the world, I had several parts laying around to build a red US90. I want to make a US90 that looks stock but has a few updates. The updates being the forks from a larger trike with suspension and a built motor. What forks can be mounted with little modifications other than the grinding of the tabs. I can get forks from a ATC 250 Big Red but would like to know all my options. I read a post in another area of this site that said all the frames are the same but it was ATC 200s forks on a newer ATC90. Any info would be great.
    mgenest is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2007
    NH
    204
    This started out as a 1977 atc 90. atc 185 front suspension forks and a kick ars GPX 177 motor...
    Sep 2007
    oregon
    2,292
    wow, that turned out great, how does it ride?
    Nov 2008
    MI
    141
    I believe your trike, mgenest, is the one that gave me the idea to do this. It looks awesome. Will the ATC 250 Big Red forks work, I am looking to mount these forks on my US90, need to know before I buy.
    Mar 2007
    NH
    204
    The credit goes to Edog on this bike. I am just the proud owner of the completed project. Ask any questions you may have. If you do put these forks on you will need to put on a stearing stopper.
    Good luck on your build.
    Baltimore, MD
    6,088
    Trizilla got the perfect forks for your us90. I sold him a set or rutt riders. That would be about the only period correct suspension for the us90. I hope you make sure that the stock frame is in pretty much perfect condition. They have a tendency to break. An aftermarket frame would be a better choice, but it is your trike. Be very careful with that stock frame.
    Nov 2008
    MI
    141
    Will a 1984 Big Red 250es axle, hub, and brake assembly fit a 1985 250es set of forks?
    Baltimore, MD
    6,088
    Sorry, can't help you there. I've never had any reason to mod any of those barges.
    Nov 2008
    MI
    141
    Is there a size difference between the atc90 and atc110 throttle cable lenght? I need a cable that is shorter in pulling.
    Nov 2008
    MI
    141
    What is the front tire and axle assembly off of? I should have forks soon, 200s. I am going to try and build a bracket to work the the original US90 fender to give it a US90 look with a modern front end.
    Jul 2006
    I would use the complete front fork assy with the correct wheel and hub for that fork as well, I like the thought of a wider front tire on a 90 over the skinny one.
    Nov 2008
    MI
    141
    Another question, will the 200x and 250r front axle assembly mount in the 200s forks? I will try and get pictures posted in the next few days of the beginning trike.
    Nov 2008
    MI
    141
    Honda US90 Build
    Here are the pictures of what I am starting with. As many of you know I built this out of spare parts I had sitting around. The blue fenders that are on it are for riding. I have a newer rear axle coming so I will be able to have more options for rear tires, I am thinking currently PW2. We need to think of a name to give it, GPX 177 is already taken. I will be sure to keep everyone updated as the build goes on. And yes that is a golf cart tire on the front.
    Attached Thumbnails Attached Thumbnails DSC04762.JPG   DSC04764.JPG   DSC04765.JPG
    Apr 2008
    Biloxi, MS
    149
    Looks good. I'm almost done with my 1973 us90 build. Can you do me a favor? Can you post up close ups of the seat and the mounting in the rear. All I have left is the seat and dropping the motor back in but I'm having problems with the seat. How does it mount in the rear? I know the front mounts with the side plates but I can't figure out how the rear mounts. Thanks.
  15. #30
    Nov 2008
    MI
    141
    I believe you are asking how to mount the fender to the frame. The grab bar has a rubber piece on the sides of where it mounts to the frame. The rear fender has two C shaped hooks that will slide over the two rubber pieces. I know it can be hard, it takes me a few tries and I have been used to them for years.
