Results 1 to 7 of 7
Thread: valve adjustments on my 200x
    Aug 2004
    Nampa, Idaho
    1,245
    What tools do I need to adjust the valves on my 200x?
    Solid Snake is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2005
    Lancaster, PA
    316
    Feeler gauges, an 8mm wrench (I think that's the size), screwdriver, flashlight. That's it. Feeler gauges you can get at Pep Boys or any place like that and the other stuff I assume you have. Oh yeh you need a large wrench to get the caps off the cylinder head cover to access the adjuster things and the flashlight is so you can see the timing marks on the flywheel when setting the flywheel to the "T" mark in the little opening.
    Trikes
    1984 Honda 200x, 1984 Honda 200m
    Bikes
    1995 Honda CR125R, 1985 Honda XL100 (gone), 1982 Kawisaki KZ550 LTD,
    2001 Yamaha TT-R 125L, 1983 Honda XL185S (current project), 2001 Suzuki SV650S
    Central CA
    459
    Make sure the engine is COLD
    86 250R
    86 250R
    86 250R
    85 250R
    82 250R
    86 350X
    81 185X
    85 250SX
    87 200X
    Sitting on my can can, doing the pan-o-ram..
    Sep 2005
    wisconsin
    475
    how ofton should you adjust your valves, like whats a good rule of thumb or about how many hours of riding
    Aug 2005
    Lancaster, PA
    316
    In the Honda service manual it says roughly every 30 operating days. That seems like overkill to me but that's what it says. I've only done mine once in the past year so maybe I should check mine out again...
    Trikes
    Bikes
    Brandon, Manitoba
    2,209
    I only adjust mine if they start getting noisy. Its real easy to do.
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Do it when the trike gets hard to start when it's cold outside.
