I have a near mint 81 r was riding a few weeks ago it sputtered and started back firing lost all power and died any thoughts on where too start looking for this problem I think its a bad piston myself
Trikes currently owned
E.T. trike 150H.P. and climbing Pure DRAG beast
85 250r project
quick compresion check shoould let you know that i'd say. woudl the reeds cause that if say a petal broke off? never seen any break tho, myself. also i ahve seen one not be worth a flip cause a rat built a dang nest in the pipe. of all the places.
well this started after a hour of riding thats what's got me puzzled
85 250r project
yea, either you broke a reed or blew it up. i would pull the reed cage out and look for any cracks or pieces missing and if they lay completely flat
when i first got my 81 250r, i was riding it and it lost power and died. it had no compression. it broke off the end of the rings on the piston. but there was no sputtering or backfiring when it happened. got a bore job,new piston and rings. good as new.
I got a roll a quarters an making change !
when the float sticks in my carb, that happens to me. id do a comp. check first though before trying to start it.
id say you
broke a reed same thing happend to me on my z
MY RIDES!
86 tri-z 270 (pigpen)
214 john deer lawn mower (35 bitches)
In my experience, if it sputters and backfires, its most likely an intake problem. If it just sputtered and died, than it most likely locked up. You probably just broke a reed like some of the other guys have said. Just get ya a set of boyosen pro stock reeds, they work pretty good.
My bikes:![]()
-1982 honda 250r
-1999 HONDA 300 Fourtrax 4x4 "The Tank"
-2001 harley 1200 sporty
well if it needs a piston I will just have too put the 300 kit on for trike fest
85 250r project
Sounds like a carb, or stator problem.The pulse coil is famous for going out,even though the exciter coil can be working! My 81 250r had this problem.
85 250r drag bike
87 trx 250r ESR big bore
