OK, i've got the oil leak pinned down (wasn't really a leak, more of a drain). Started as a drip and has gotten worse lately. Only leaks w/ trike running. Dry as a bone when turned off. Honestly, I'm a biologist, not a mechanic like many of you so any tips would help. I know its not the flywheel cover or the recoil, or the main bottom of the engine, but somewhere in between. Is it a bad seal or ring or something?? Any tips would help . I'm pretty handy and really don't want to take her into a shop at $40 an hour for labor if I can help it....Thanks
bobbyg
