Results 1 to 13 of 13
Thread: Loud and smokey
    Wales
    92
    Arrow Loud and smokey
    Ok so i got my atc 110 going, but in neutral it gets increasingly louder, and starts to get smokey. There is also a little oil leaking somwhere. If you put it into 1st geaar, it leaps foward and goes off on its own, with no accelleration. Please help, what do i do? cheers, luke
    Oct 2005
    North Branch, MI
    196
    throttle sticking?
    Cody's Avatar
    Cody is offline Just Too Addicted Arm chair racerJust too addicted
    Feb 2005
    FLORIDA
    731
    Needle and seat. Float. One or the other.
    1985 Yamaha 200E Shaft - New Toy / Project
    1983 Yamaha YT175 - Kinda retired?
    Mar 2005
    Parma. Oh-sub of Cleveland
    472
    Turn your idol screw down alittle big, the only reason it doesnt do it in gear is because the load on the enigine, i had a trike do that, all you have to do is adjust that screw.
    1985 350x
    1985 Tri-Z
    1983 200
    Atc 70
    1985 200s
    -parts for sale
    1985 Polaris Indy 500
    1986 Polaris Indy 400 liquid-For Sale
    1988 GMC sierra 1500
    Wales
    92
    thanks for the replys, i have a problem, i just bough the trike, and the screw seems to have broken off, so i cannot losen it. any suggestions?
    florida
    2,328
    i have that same problem on two out of my three trikes
    Mar 2005
    472
    ...oh thats really not good.. lol can you even get ahold of it with like tiny needle nosed vise grips? if not you really need to find a new one, or carb that fits it. I think you could get a 125 carb on there if you needed too, not sure though. good luck though.
    1985 350x
    1985 Tri-Z
    1983 200
    Atc 70
    1985 200s
    -parts for sale
    Wales
    92
    i'm gonna try to cut a groove in it so i can turn it to losen it. If this doesnt work, damn, i'm screwed. excuse the pun lol
    florida
    2,328
    lol yea i think its a reele bad design flaw
    May 2005
    Southern NH
    1,489
    Drill a hole with a wicked small drill bit, then jam a piece of metal in there with the strongest glue you can find. Before you try and turn it SOAK it with PB blaster....should work....
    "I have but one lamp by which my feet are guided, and that is the lamp of experience." -Patrick Henry
    NEW ENGLAND ATC owners please join!:http://www.3wheelerworld.com/group.php?groupid=27
    Aug 2005
    michigan
    125
    I had the same problem just get a new throttle cable and check your spring. And if it smokes check to see if theres and thing on it that could be making hot. Well tell me if that helped
    Tim
    springville, PA
    6,185
    do the idel screw first. most likely that your problem, plus its free to check.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Wales
    92
    Thanks guys, will try a few things and let you know how i get on.
