Results 1 to 15 of 15
Thread: Stripped Screw Head
    Apr 2006
    Miami FL
    47
    Stripped Screw Head
    Well I am re building my 200X and disassembling the head. I got everything down to the phillips head screw that holds the plate, which holds the rockers in place. Well you guessed it, being a phillips head screw and alot of torq I managed to round out the head on the screw. What can I do. I am temped to just leave it together and re oil it, but i really would like to get the rockers out.
    Any Suggestions?
    Thanks
    mean350 is offline Just Too Addicted Arm chair racerJust too addicted
    uniontown pa
    472
    can you get a pair of vise grips on it? that always works for me.
    Apr 2006
    Miami FL
    47
    No, thats what sucks, the screw is countersunk.
    Brandon, Manitoba
    2,209
    You'll need an impact driver, that should work to get it out.
    I bought one for $9.99, best tool I have. If you own a yamaha, this tool is a must, because of all the phillips bolts on the case covers.
    Good Luck
    I use one of those manual Impact screwdrivers for situations like this.
    (looks kinda like a fat screwdriver that you hit with a )
    Brandon, Manitoba
    2,209
    Yep, thats the one im talking about g&w
    Apr 2006
    Miami FL
    47
    Quote Originally Posted by Yamahauler
    Good call. I think im going to buy one of those.
    Anyone else have any suggestions.
    Apr 2006
    Miami FL
    47
    I got to thinking, and there is no way that could work, I think the head is already striped to badly.
    Ha!
    I think Yamahauler and I were writing our response at the exact same time!!
    ....well you have 2 recomendations then! these things really work great.
    good luck with the trike!
    Clarks Summit PA
    1,236
    Sears sell this bit type set that may catch it as it drills.. its for stripped out heads..I have used it with success.. just head into the store and start looking,. the set is cheap enough, like $20 for 3 different size bits
    Ride it like you stole it! And never look back! They are too far behind to see!
    Randolph NY
    597
    Can you possibly super glue or epoxy the screwdriver into the screw and push down hard while turning and maybe get it out? I did that with my R in a few places with success.
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,248
    very simple ,, just drill the head off and take it apart,,, then get the rest out with vise grips,,,,
    danteross77's Avatar
    danteross77 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2005
    Texas
    339
    You need a drill bit with reversed threads, I bought a set a harbor freight tools for under $10. Its a ordinary bit but the threads go the other way, put it on start drilling and the screw will come out with ease. Saved my ass on many occasions.
    Oct 2005
    North Branch, MI
    196
    the impact driver i bought was by far the best tool ive ever bought. just like yamahauler said, they are a must for a yamaha. the impact driver should get it out.
    Pa.'s Highest City
    8,058
    EZ outs are a guys best freind for these situations. they also sell some kind of exopy stuff that you put on the head of the screw and it hardens around the tip of the driver. Never used this stuff myself but I was told it works and is a cheaper alternative.
