Hi. I am new here as I have recently been trying to get my 1983 ATC 200 Big Red going. All I need to do is to change the chain and sprockets, but my Haynes manual is unclear about my particular model. In all these cases, my manual indicates something different-maybe true on other models it covers.
Here are the problems I am having:
1. The rear brake drum won't come off. According to the manual, it should just slide right off. I muscled it to the point I thought I should stop or else something would break-which has been known to happen. I got the 2 nuts and tapered washer loose, but can anyone tell me what that collar-type thing is and what comes next? I think it’s attached to the drum, but neither one budges.
2. In front, what are the things i need to take off to get to the drive sprocket? I didn’t want to take a ton of stuff apart if I didn’t have to.
The neutral indicator- I don’t even know how to get that off
The box that engages the high/low range- I took all the bolts out and it doesn’t even budge. The front sprocket is behind that so I assumed I needed to take that off to get to it-along with the crank case cover.
3. The rear sprocket –does the whole axel have to be pulled out from that side in order to undo it from the back side? That’s what the manual says and I see no other nuts/bolts to remove.
If anyone is familiar with these things, I would be indebted to you for your help. I try to do all the work on my wife’s and my vehicles. There is always some extreme learning the first time. ATVs are not something I am very familiar with. What other surprises did you have when you did this work? It would be nice to know what I can expect.
I have been itching to get out and ride again. I am from the north woods of Wisconsin and have been trying to get home to ride around again. Stuck in Minneapolis is nowhere to be.
-Jess
