Well we picked up another 230. Not to sure of the motor if it’s a runner or not. The side cover and clutch was removed when we picked it up. I pulled the clutch from a parts motor but still need the oil filter and cover before we try and start it. I think we are going to pull start it because it just doesn’t seem to have much compression. I hope that it is from sitting for some time with out any oil in it. Maybe it’s a timing issue. I need to get it to spark also. Changed the cdi and the coil with no luck going to change the stator to see if that will work. Anyone know of anything else that would prevent it from getting spark?
