Thread: what light bulb goes in the tail light
    Apr 2006
    Ontario Canada
    19
    Question what light bulb goes in the tail light
    I have an honda atc 200 1982 I was trouble shooting electrical problems when i took out the light bulb in the back the head light came on ??? the one that is in there is a 6v5W is that the right one?
    p.s. this model does not have the optional DC power kit with a battery.
    Des Moines, IA
    1,303
    Yeah, the original is a Stanley 12v5w. I went on a crusade a couple of months ago trying to find those bulbs, and finally gave up and put a standard automotive 89 bulb in. It's about 7W, but seems to run without a problem. Then I found a vendor that had the right bulb....and lost it. If I find it again, I'll post it here.
    God knows they're not looking to make any effort to do anything, never mind move their foot to shift. If there was something that dispensed Cheetos every time they shifted that might be a different story. Welcome to America, where the biggest is best and even fat people who are too lazy to shift can climb a mountain.
    Apr 2005
    Easton, MO
    142
    Got some of the stanley bulbs at WalMart. Cost 1.10 for two in a green package. They are located with the rest of the automotive lights.
    Apr 2005
    Easton, MO
    142
    I just went out to the garage and they are GE bulbs not Stanley. I run them in my 85r without incident, and they are 12v5w bulbs with the same profile as the Stanleys. GE number is 67 67/BP2.
    Des Moines, IA
    1,303
    Ordo is correct, it is the 67 bulb that I've been using. The specs are (approximately) as follows:
    GE 67 12v7a
    GE 89 12v7.5a
    Clearly, both will work, but I'm a believer in being as close to the original as possible, and the 67 is closer. However, I have seen with my own eyes that the ATC's in my garage don't have a lot of wattage to spare, and the higher wattage bulb takes away slightly from the headlight output. That's why I'd rather use the original 12v5w if I can find the *&*!@#$ thing!
