Results 1 to 13 of 13
Thread: Rotary valve blow back ?????
    Mar 2005
    Underwood North Dakota Tiger country
    1,055
    I just looking for some thoughts on a rotary valve 2 stroke the tiger will start and run just loading up severly. with the air filter off you can see the gas blowing out of the carb. this thing will soak anything in it's way tires legs etc... I know with a reed type engine that the reeds would be leaking and need replaced has anyone dealt with these rotary valves and would the rotary valve be bad ???
    Trikes currently owned
    E.T. trike 150H.P. and climbing Pure DRAG beast
    85 250r project
    Lancaster, PA
    1,738
    Don't know much about them(yet!) but I would start with the rotary timing.
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    daputz is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2004
    a proud cheese head
    207
    I agree, check the valve timing.
    If the valve timing is spot, on the the valve has way to much slop (front to back), or the burn is severly inefficient.
    If you can't find the trouble your self, a good pwc tech should be familiar with your set up.
    Mar 2005
    1,055
    I'm on a learning curve myself right now I will solve this one by trikefest I have another engine really close to being ready and may just switch them out for the fest
    85 250r project
    Mar 2005
    1,055
    Is it possible that its just getting way too much fuel as it won't idle just full throttle. If you shut off the fuel it will run more normal as it is about out of fuel in the carb Remmeber I don't know where too start at jetting these and they seem too be larger jets
    85 250r project
    Mar 2004
    a proud cheese head
    207
    pm me with the engine #'s, I'll search the archives at work and see if I can find a rotary valve that is comparable.
    Edit..............float height? is the carb overflowing while stopped?
    is it possible the needle length is too long? shutting off flow at anything below wot?
    Mar 2005
    1,055
    ok will do I need too get too the grocery but will pm you as soon as I'm back Thanks
    85 250r project
    Mar 2005
    1,055
    ! thing I thought of I have a can am 250 carb here its a bing 84 off a air cooled may be that's a good place too start
    85 250r project
    Mar 2004
    a proud cheese head
    207
    reply tag ........your it
    you type way too faast for me to keep up
    Edit....................the can am carb would probably be close, not ideal but a good base line, the jawa specs are also in the ball park compared to the can am. I have no clue as to what the tigers were set from the factory.
    Aug 2004
    Ab Canada
    4,368
    Quote Originally Posted by daputz
    Same carb, Is the tiger have a BING carb? they are notorious for having bad seals in the Choke-assembly, causing them to run real rich ect....but it sounds like your roatary valve timing is off....my friend had the same problem with his Cam-am 250...i can see if he know's how to set it right (dont know if he ever did)...and will let you know..
    1985 Tri-Z-
    Lancaster, PA
    1,738
    I checked my Tiger 200 manual and Rotary Valve timing disc opens at BTDC 142 degrees and closes ATDC 85 degrees + or -3 degrees. Don't know if its the same or not, no carb info. Thats all I got. Good Luck.
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    and many more!!!
    Blue Line Graphics
    Mar 2005
    1,055
    I found a manual for the air cooled 250's and according too Tony murphy rotax it's really close but the carbs they talk about are the bing carb's
    85 250r project
    Mar 2005
    1,055
    THe rotary timing is close I have a gage that was made too set these this engine will get checked again tommorrow I know 1 tooth off and it will run like crap
    85 250r project
