Alright, I'm at the end of my ideas. I have a stock 86 triz 250. Starts briefly then sounds as though it is getting too much fuel (plug is wet) and dies out. I kick it 5-6 times and it backfires terribly. I have set the jets as they should be, it is getting fire, I have new fuel in it, the fuel pump seems to be working properly. The main jet is a 300. I have the float set as it should be. It did run with the main jet loose (idled and revved) but when riding and opening up, lost power. The guy I got it from said that the piston and rings were new. It has a DG after market pipe. I have set the needle to middle, high, and low to try different things. It simply will not run and I am at a lost. Any help?
