well, when its sitting there idling and you gas it will it rev up? if it wont rev up and just bogs you could have a small hole in your piston, but it sounds like you just torched your crank. i recommend pulling the top end off and checking things out, especially the crank, make sure it rotates easily and doesnt feel at all "rocky" and the rod doest move side to side very much. if your sketchy about judging the crank for yourself take it to a good shop. its not worth letting the rod let go or the mains. a 100$ for mains and a rod kit is a lot cheaper than 250 for them plus a piston kit and a bore job after she pops her cookies. oh yeah, and word of advice...unless its a race motor, it isnt designed to be run WOT for more than 10 seconds at a time. and if you feel the motor getiing hotter and hotter, stop and let it cool down. crazy bastardo!
