Page 2 of 2 FirstFirst 1 2
Results 16 to 29 of 29
Thread: could i put banhee exaust on blas?ter
    Dec 2005
    new jersey
    44
    true thanxz im debateing on sellin it so if i keepit im gunna try to look into it
    Sep 2005
    Lipetsk, Russia
    2,824
    Arent the bends on the banshee pipes totally different, though? You'd have it sticking way the hell out there, or it might not fit at all because it would be sticking into the engine case or something.
    Nov 2004
    Mass.
    90
    You might be able to if you use the blaster expansion chamber and build it from there. You would have to make a one to two Y thingy and fab the shee pipes to fit the bike. You won’t have to worry about the pipes being balanced because you’re only running on a single cylinder. Stock banshee pipes are very restrictive as far as exhaling the exhaust but you will be increasing your flow by almost two so you will have to bump up your jetting some I would think. I had put a stock banshee silencer on a 200x before and it lost some top end but I didn’t re jet it because I wasn’t going to leave it on the bike. I just wanted to try it to see how it worked
    Parts for sale
    85 KX250 Roller with engine
    KDX motor
    2004 E-Ton Viper 50 Needs work
    Honda 87 Fat Cat Roller
    Honda 200m motor
    Honda 110. 80 frame 82 motor For parts. Runs.
    Honda 84 ATC 70 Roller Cheap.
    XR75 complete bike
    XR80 parts
    Yamaha 225dx parts.
    Honda 84 200es parts Good bottom end. (quad conversion front end)
    Kawasaki 93 KX80 Motor (needs piston & bore)
    Yamaha 88 YZ125 cases
    Suzuki 85-87 LT230s 2 complete parts bikes.
    Honda 83-85 200x Parts
    Honda 86-87 200x Parts
    May 2002
    Southeastern Wisconsin
    3,658
    Quote Originally Posted by Big D
    So you think 3 pipes?
    Nov 2004
    Mass.
    90
    pipes
    Quote Originally Posted by OldSchoolin86
    LOL No leave the expansion chamber on the quad and build the new system from the tail end of the expansion chamber. (the outlet) LOL
    Rittman, Ohio
    6,276
    Okay, Im trying not to go nuts here. Less restriction is not an automatic good thing. More restriction is not an automatic bad thing. Two stroke pipes are finely tuned instruments whose purpose is to control the when, where, and hows of putting the flow restrictions and flow enhancments in all the right places for a desired outcome. This is done by varying the header length, and length, shape, and size of the expansion chamber, along with the size of the reduction at the end of the expansion chamber. One of several key factors in building a tuned pipe for a certain outcome is volume going through it which is mostly affected by engine displacement.
    In plain English, this means that a dual pipes designed for a 350cc twin, rigged up to a single cylinder 200cc motor will make it run like TURD no matter what. If you wish to drive a TURD, then GO FOR IT! If you paint it, it might be a pretty TURD. If you dry it out, it might be a durable TURD. If you squish it, it will be a broken TURD. If you modify it, it will be a fancy TURD, but no matter what, it will still be a GREAT BIG TURD.
    "I had put a stock banshee silencer on a 200x before and it lost some top end but I didn’t re jet it because I wasn’t going to leave it on the bike. I just wanted to try it to see how it worked" ---- The priciples of 4 stroke theory and operation are completely differnet than 2 stroke operation.
    If you want a good exhaust for a Blaster, then go buy a Blaster exhaust. If you want a good exhaust for a Banshee, then go buy a Banshee exhaust.
    Sep 2005
    Lipetsk, Russia
    2,824
    Um... what he said. LOL
    Dec 2005
    new jersey
    44
    lol ok does this mean i should take the blaster pipe off of my lt 230? lol im surprised no ones killed me yet and i think were going to do dual straght pipes on the lt next that will work i gaurentee it
    May 2005
    Dorset United Kingdom
    1,408
    Quote Originally Posted by jrsyredneck
    Just buy a banshee.........
    85 Tri-Z "Rumble Bee"
    85 250R "Red Rocket"
    83 200X "Flat Tracker"
    yyz4208@aol.com is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2003
    291
    How the hell did you put a blaster expansion chamber on lt230? I have had both machines
    Dec 2005
    new jersey
    44
    Absolutely NO racial slurs!!!
    OldSchoolin86
    3WW Moderator
    Nov 2002
    Victor NY
    538
    Dec 2005
    new jersey
    44
    my apologies
    Oct 2005
    saratoga, ny
    2,819
    for anything blaster go to projectblaster.com , they are the guru's of the blaster, along with trenga racing as well. and no, a banshees pipe wont work on a blaster. they have tons of stuff on their site, from disc brake conversion kits to motors to plastics, graphics, etc. you need it they probably have it.
