I have a perfect running 1988 trx 125 motor and was wondering what it might fit into as far as 3 wheeler frames are concerned. I know it will fit the 86-87 atc 125 frames, but what about any other, more common ones? Thanks
John
John
74 K-2 ATC 90
83 ATC 110 "Blue"![]()
83 ATC 185s
84 ATC 110
84 ATC 200x
85 ATC 250sx "stud"
87 BIG RED (Project)
:QuadsOwn![]()
85 TRX 125
86 TRX 125 X2
atc 110 with a lil modification
WRONG!! The 87-88 TRX and 86-87 ATC125m motors are completely different than the 110 motors. The 110 motors are a lay down style, while the 125cc's I listed above are a upright style.Originally Posted by team-red-rider
You might be able to fit the motor into a 185-200cc chassis, but you wuld need to modify things a little. The 125 uses a 420 chain and the bigger machines use a 520 chain. The electronics are a lot different, and more.
Howdy
Ohh my bad srry i was thinkin the old style 125m motors that are almost the same as the 110
it'd be cool to put it in a 200x![]()
JASON LISKEY
2 = 86 atc 350x's
86 atc 250r
