Results 1 to 15 of 17
Thread: Backfire out exhaust when let off???
    Apr 2005
    Chicago
    15
    Have gotten my trike running pretty good only problem left is when I let off the throttle and the engine RPMS drop I got some minor backfire out the exhaust .
    What carb adjustment should I make?
    Lower the main needle a clip? or what?
    Any suggestions would be greatly appreciated, thanks.
    85 YTM 225DRN
    85 CB650SC
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    My Big Red does that, might be getting to much fuel, its nothing big it dosent make much different, mine does it going down a hill mostley, I think it sounds kinda cool. Sometimes they just do it, but they run fine.
    TF 07,08,09,10,11,12,13,14!
    Apr 2006
    Crestview, Florida
    2,429
    thats caused from to much fuel. loading up.
    Apr 2005
    Chicago
    15
    Quote Originally Posted by Erics350x
    I figured it's running rich on the high end, What's the proper carb adjustment to correct the condition?
    Main needle down?
    Needle jet down?
    Back out Piolet Air screw?
    Something else?
    85 YTM 225DRN
    85 CB650SC
    Apr 2006
    Crestview, Florida
    2,429
    start simple with the adjustments, see if that helps.
    Tionesta, PA
    5,747
    Are you running stock exhaust or aftermarket?
    Apr 2005
    Chicago
    15
    stock exhaust with a uni filter
    85 YTM 225DRN
    85 CB650SC
    ??? seen it happen with aftermarket pipes, cant recall ever hearing it with a stock tho..
    Mar 2005
    Alberta
    503
    Could be an ignition timing issue but I think it is just too much fuel. Either an incorrect adjustment, plugged jet, floats too high or a leaky needle/seat. Also check & make sure that the choke cable tension (freeplay) isn't too tight. If it is even just a little bit tight, it will let extra fuel into the carb causing it to run rich. How's the plug look?
    A whole bunch of trikes.
    Jun 2004
    Pyeongtaek, South Korea
    474
    The thoughts about too much fuel are logical, but it could also be something as simple as a leak in the exhasut system. My buddy's YZ426 started popping once while we were riding, and we found a crack in the muffler's stinger. It pulled air into the exhast when he chopped the throttle, and that was enough to ignite the small amount of unburnt fuel.
    Operation Iraqi Freedom V and Operation Enduring Freedom X veteran
    The Constitution and Bill of Rights were written in common English for the common man. There is no interpretation necessary.
    "To err is human, to err continuously is liberal." - Me
    Apr 2005
    Chicago
    15
    hummmm, good Idead, I'll check the exhaust, it's not bad but the header piped is pretty beat might have a crack, have to check it out. Otherwise I'm still leaning towards carb adjustments. Going to figure it out soon.
    Today going on vacation, in 2 hours loading up the ytm225 and atc200m and heading up to the Hardy dam in White cloud michigan to hit up my ladys family cabin of
    +200 acres of three wheeler goodness.
    85 YTM 225DRN
    85 CB650SC
    Oct 2006
    Alexandria Bay, NY (Northern NY)
    51
    Quote Originally Posted by 69HemiGTX
    My 1985 1/2 Yamaha Tri Moto 225DRS did the same thing for a long time. I went to change the stock exhaust pipe to a DG and found that there were 2 small 1/4 inch hole on the bottom of the pipe. Plus the head pipe gasket ring was not there. Now with the new exhaust and gasket it has never backfired or popped since ?
    John
    1985 1/2 Yamaha Tri-Z 250
    1985 1/2 Yamaha Tri Moto 225 DRS
    1983 Yamaha Tri Moto 225DX
    1985 Yamaha Tri Moto 200
    1984 Yamaha Tri Moto 200
    1985 Yamaha Tri Moto 125
    1984 Yamaha Tri Moto 125
    1985 Yamaha 60 Zinger
    1991 Yamaha Blaster 200
    1989 Yamaha Warrior 350
    1984 Honda ATC200ES (Big Red)
    1985 Kawasaki KLT200C
    1994 Suzuki RMX250
    1980 Yamaha IT250
    1972 Suzuki GT550
    1978 Suzuki 450L
    1982 Yamaha Vision XZ550
    sako is offline New to the board Arm chair racerNew to the board
    Sep 2006
    Australia
    48
    my 70 does it with aftermarket pipe, hasn't bothered me too much.
    looks good at night!
    Nov 2006
    AZ
    139
    Popping through the exhaust on closed throttle deceleration is most often caused by a too lean pilot circuit (on a four stroke). If it's mild and unobtrusive popping then it's not a major concern--there's a temporary leaning effect that occurs under that particular running condition (it's just a fundamental deficency in the way carburators work). A "perfectly" tuned pilot circuit will sometimes (often?) cause slight/mild popping on decel. If it's a very loud "machine gun" type of sound then it should be addressed. Try turning the fuel screw out a turn or so. If you get to three turns out with no relief then go up on the pilot jet.
    Exhaust leaks can also cause closed throttle deceleration pops.
    A too rich pilot circuit can also cause decel popping but the nature of the pop is a little different. Rich popping is "wetter" sounding--more of a blap than a pop. And in my experience, you have to be very rich for this to happen.
    Quote Originally Posted by GPracer2500
    Nice post, My SX would pop like crazy until I backed that fuel screw out an additional 1/2 turn. No other adjustments were made.
