Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Thread: Backfire out exhaust when let off???
    mad_max is offline Just Too Addicted Arm chair racerJust too addicted
    Kansas
    462
    Quote Originally Posted by GPracer2500
    .....If it's a very loud "machine gun" type of sound then it should be addressed. Try turning the fuel screw out a turn or so. If you get to three turns out with no relief then go up on the pilot jet.
    My SX (w/ aftermarket pipe) does the machine gun sound. if I turn the mixture screw out it will lessen (but not totally eliminate) the problem. The down side to this is that with the mixture screw turned out further my SX does not return to idle as quickly as it does on the stock setting.
    Steve ('crasher), do you know if pilot jets are replaceable on the SX carb?
    Thanks
    Mike
    Quote Originally Posted by mad_max
    Thanks
    Mike
    I beileve thats the jet that is pressed in the carb on an 85. You get a larger one in the hard start kit but other than that you'd have to drill it out and risk shavings lodged inside.
    Solutions are - buy an 86/87 SX carb which has threaded jets. Or - buy a 350X carb.
