1978 Honda 90
1st) a) 1978 Honda 90 makes a strange rattle in 3rd gear either Hi or Lo range has snapped drive chains twice in 3rd gear doesn't have issues in any other gear can't see a wobble in the drive line while its on blocks in any gear. b) quits after 8 to 10 min of riding and you need to wait 5 to 10 min to start it again --assuming this is probably the coil?
1984 Tecate 3
2nd) T-3 isn't "hitting" the power band hard, goes fast enough --60 MPH+ , no shortage of power,just doesn't rip your arms out of the sockets, second rider other than me feels like its choking -- ie air starvation?? just before the power band, but will spin the wheels from 5500 rpm up to 6500+ rpm in gravel 1st through 3rd gears. Everything is stock from the rebuilt carb (stock jets) forwards and backwards including bore/ stroke, tranny, sprockets, (compression is 182) stock air filters, stock reeds, new stock scilencer (sp?) and stock collector, BR8ES plug, 8mm plug wire.
getting a little frustrated with it right now
