Check out POR15 on ebay . Work great on my tank , even seals pin holes and seam leaks.
Make sure you take the fuel petcock off the tank before you use the acid. You will end up with junk if you forget.
One piece at a time. Status: The Beast is Done..06-23-07
Back in the saddle again![]()
Currently owned rides:
My sleds, and.........
1995 CBR600F3
1976 Kaw 400 triple-smoker......SOLD
1986 250R...owned since 1990
06-23-07........the R is finally done!!!
ESR pipe, Aktive reeds/CR cage, 38mm PWK, +4 Dominator
mild clean-up porting, an open K&N, CR and YZ calipers.......among other things
