ive got a 86
heres the prob
start with last fall, the trans didnt want to down shift into 1st to well.
i adjusted the clutch this spring and everything seemed good last weekend, than this weekend ( memorial ) issues again, i realized it wasent the new riding boots causing missed shifts
oil is full and changed last september
what's happening is
hot or cold - with or with out clutch and any gear now, it dont want to down shift ( does not bind, no noises ) its like the gear is gone.
hot mostly it wont up-shift sticks in 3rd,4th or 5th.
ive tried to feather the throttle to get it to shift, tried all the tricks i know to get it to shift nothing works consistant. it does seem to up-shift more often under low rpm shifts but not all the time.
when it does shift it feels fine. i did notice when NOT running it dont always shift and the gear shifter will stick up but dont bind.
any help i would appreaciate so i can make it to TF06
thanks larry 734-953-8676
