Results 1 to 3 of 3
Thread: 1984 yamaha tri moto 200L running but revs near wide open at start help
    timex69 is offline Just Too Addicted Arm chair racerJust too addicted
    Sep 2003
    Saskatchewan
    485
    hey
    I just bought a motor off ebay for my 1984 yamaha tri moto 200L, it has good compression and all new gaskets in the top end, I primed it n it fired up first pull but it started reving real high, the exhaust isnt on it yet and its missing the choke cable. Could it be air is getting in through the choke cable hole mabe? let me know what you guys think,
    Thanks
    alex
    Mar 2005
    Alberta
    503
    Either plug the hole or get the choke fixed & see what happens. It will suck air through there causing it to rev & run real lean.
    If that doesn't help, make sure the throttle cable isn't too tight or misrouted.
    Also, maybe the idle speed adjustment screw is set too high.
    A whole bunch of trikes.
    Sep 2003
    Saskatchewan
    485
    can someone give me the screw adjustments for this carb
    Thanks
    alex
