I remeber reading that a complete xr/xl 500 top end bolts on to the 350x bottom end. Is this true? If so i think im gonna be building me a 500x sometime soon?
Or was i realllly tired when i thought i saw this?
Thanks! Cragster
Thanks! Cragster
'86 200x
dont know if it works but that would be awesome!!!
yeah thats what i was thinkin! i coulda swore i read it though....
'86 200x
Yes,you were really tired.Originally Posted by cragster
85/86 ATC 567x
Bailey(11/30/97-4/17/06) My little angel
You think so? So theres no way this will work?
WHat about a 400ex/450r/crf450 etc etc?
Im for real i swear i read it
'86 200x
Give me a minute or 2,gonna send a pmOriginally Posted by cragster
85/86 ATC 567x
i read on another form it would work but only a couple of years. and the cases had to be modified. it also said that the gain wasnt worth the trouble. it stated that the big bore kit made alot more power.
It doesnt bolt up, I dismissed this myth a long long time ago. With extensive center case welding and machining yes it might be possible. The heads however do for the most part seem to bolt right in place of each other. THe difference being the rocker cover with the top head stay mount for the XR500 engine is near the front of the engine insteead of the back. It hits and rubs on that backbone of the frame where the airbox tube hooks to. More trouble then its worth IMO
I was told that the xr 500 headpipe mounts up, however and is BIGGER. and everyone knows bigger is better. He said it made it work a hell of a lot better
Caution
Do not "POP WHEELIES" and run for any distance with the ATC. The oil capacity is relatively small and the oil will drain out of the oil pump area thus causing loss of oil pressure, resulting in costly engine damage -CLYMER
what about just swaping the 500XR engine for the 350X engine. Would it be a pretty easy swap?
I had 1 of these xr500 conversions it was a cobbled mess with all the frame mods it takes too make the 500 fit
Trikes currently owned
E.T. trike 150H.P. and climbing Pure DRAG beast
85 250r project
i remember reading about that in dirtwheels or something. They did a 500 big bore 350x and It seemed like it was a bolt on mod? of course that was probably 15 years ago when I read that.
85 atc 250r;
PSI porting & head mods
fmf pipe & silencer
boysen rad valve & reeds
38mm air stryker
hi i dont know how -because of the cam timing!!! the cam sprockets the same?
maby your camsproket if cylinder fits
its not worth the hassle, a bore kit and cam will get you more power. the only advantage is the 500 head has bigger valves and ports, but thats only an advantage on a bigger cc motor. the top end is oiled internally on the 500 and you have to do some drilling in the 350 cases to make it work. put in a 452 bore kit, cam, and fcr carb and you'll have plenty of power for a 350x.
where do *Edited* get a 452 bore kit, cam, and fcr carb at anyways?
