Results 1 to 15 of 19
Thread: 250R front brake bleeding trouble
    Jul 2004
    Ontario, Canada
    124
    I'm having trouble bleeding my front brake on my 86 250R. I have just finished a complete restore and can't seem to get the front brake bleed. I have put on braided lines and had no trouble bleeding the rear. I initially had a leak in the front master cylinder so I rebuilt it and the leak went away but it would not bleed. I have since taken my master cylinder from my CR250 (which i know works) and installed it and the system will still not bleed. There is no brake operation at all. Does anyone have any ideas?
    Pa.'s Highest City
    8,058
    The brake caliper is not frozen is it?
    You can try this... fill the MS with fluid. (make sure your resivior doesn't run dry with fliud... keep filling as necessary) loosen the beedernut. Queeze the lever till fluid shoots out. REtighten the bleeder nut. Repeat this process until all the air is out of the lines. So what I'm saying is loosen and retighten the bleeder everytime you squeeze the lever. This same process worked for me
    Jul 2004
    Ontario, Canada
    124
    If the caliper was frozen there would be resistance in the brake lever.
    That is the method I use to bleed brakes. The rear was not trouble.
    kb200x's Avatar
    kb200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2005
    KY
    295
    you can also try to crack open the bleeder to where it just barely drips out fluid and fill it full of fluid and go have a beer come back and fill it up again shake the line around a little and go have another beer. let gravity do the work of getting the air out. let it set and drip for a while and shake the air out and keep fluid full in 30 or so minutes try to go back to what chris was saying. Works for me anyway.
    86 350x "O' Smokey"
    83 200 auto X
    84 200x
    85 110
    82 70
    r00sty's Avatar
    r00sty is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2002
    Hemlock 14466
    415
    The problem is that your system is dry, and won't make a vaccume to suck the fluid through, this question has been answered 100 times at least, anyway here is what is needed, the short version.....
    You have fluid in your res, so crack the line at the caliper to make sure fluid is down there, once there is, try the bleeding method, pump it up, hold, bleed, tighten, etc. etc. Always keep fluid in the res., and if you don't get pressure, you might have to either...
    1. Let gravity help you, I let my bleeder stay open a crack over night with the res. full and it worked it's way down, or..
    2. Put a clear hose on the bleeder and loop it up towards the bars and open it up, and keep filling the res. until all is full. Good luck....
    Old enough to know better, but still young enough to not care!!!
    Reality is for people who can't handle drugs!!!
    86 XR250RX Custom but all Honda...
    92 Yamaha Vmax
    81 Yamaha XS1100
    04 Polaris 700 Twin EFI
    86 TRX 250r
    mean350 is offline Just Too Addicted Arm chair racerJust too addicted
    uniontown pa
    472
    what i did on my 350x is cracjked open the bleederand put a small hose on it and stuck the other end in a brake fluid jug.i was having the same problem as you. it takes about 30 seconds!!
    Jul 2004
    Ontario, Canada
    124
    The system is not dry. I have fluid coming out the bleeder. I have used the gravity method as well. I have even put a long peice of hose on the bleeder and sucked the fluid through. There is no air in the system. I just don't get it.
    illinois
    743
    blow the lines out with air/and mastercylinder collapse the weel cylinder clean it out see if master cyl pumps with out caliper hooked up
    Ontario, CANADA
    4,538
    X2 guy, I had this same problem as well. I let it gravity feed for ages, tryed the hose trick nothing worked. Worked for 5 hours one day, then when I couldnt get it I walked away. Came back the next day and re read the manual, and tryed it one final time. And I got more bubbles coming out the hose off the bleeder! So I did it a few more times and wola I had breaks.
    Seems to me the air bubbles settle, I would allow a good day or two then try it again.
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    Jul 2004
    Ontario, Canada
    124
    Thanks. I think what I'll do is take the whole front brake system off and let the caliper hang straight down. Hopfully I can get gravity to do it's thing
    Jul 2004
    Ontario, Canada
    124
    I finally spent some time on this thing last night. I put my CR master cylinder back on the CR and didn;t even have to crack the bleeder. I pumped it a few times and all the air bled out. I tried the same with the 250R master cylinder on the 250R and no go. I tried again every method I could think of wit no luck. I then took the CR cylinder back off and put it on the R, worked the lever a bit until all the air came out and finally I had breaks. Looks like ther was something wrong with the R cylinder after all.
    yater is offline Just Too Addicted Arm chair racerJust too addicted
    Jun 2003
    Tyler, Texas
    672
    Back bleed it. It takes 3-5 minutes and works 100% of the time. I'm sure I've posted a "how to" in the past. You'll need about $10 worth of "stuff" to do it. I'll never try it any other way again.
    Jul 2004
    Ontario, Canada
    124
    So what you mean is force the fluid in through the bleeder? I tried that with a squeeze bottle and hose. Didn't work. I like the method I used with the CR master cylinder. I just pumped the lever lightly and watched the air bubbles come out. the caliper was already full. If the system was dry this way would have taken much longer I'm sure.
    Mike_Ham_250R's Avatar
    Mike_Ham_250R is offline Even team-red-rider is cooler then me. Arm chair racerJust too addicted
    Pennsylvania
    1,058
    Quote Originally Posted by Kintore
    This is EXACTLY what happened to me on my 250r. I feel your pain X2 Guy, it took us (3 men) 2 days to put pads on and bleed it.
    -Mike
    Jun 2003
    Tyler, Texas
    672
    An "old style" oil can with the thumb pump works best. The squeeze bottle needs to be big enough not to have to "pump" it (needs to be one continuous squeeze until reservior is full). Also, the tubing should fit snugly over the bleeder nipple....not the banjo bolt (I've seen some try it). I've done this for years on my bikes and others and it has always worked first try.
