Thread: ATC70 rear sprocket removal...what am I missing.
    Jul 2004
    Here
    126
    Besides the knowledge to remove it?
    I took the wheel off, the hub and the spacer behind the hub, and that was as far as I got.
    Do I need a puller to remove the rear sprocket or a bigger ?
    Is it possible to just flip the sprocket, the teeth have worn in one direction, seems I could get some more life out of it by flipping it, or is there a reason thats not possible? If thats impossible, I'll just plan on buying another.
    Someone give me a parts company that included many exploded views, yet seem to have lost the link, anyone know the one I speak of?
    Any thoughts appreciated.
    May 2005
    Dorset United Kingdom
    1,408
    There is a sleeve that slide over the axle.... have you removed it? it might be rusted on.
    85 Tri-Z "Rumble Bee"
    85 250R "Red Rocket"
    83 200X "Flat Tracker"
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,250
    THE SPROCKET WILL ONLY GO ON ONE WAY,,, YOU WILL NEED A NEW ONE,, AND CHAIN AND FRONT SPROCKET,,, the sprocket hub just slides off the axle so i would say you have some corrosion going on,,,,
    Jul 2004
    Here
    126
    Thats what I figured...got the sleeve off no problem...the sprocket hub is giving me trouble...just slides off....
    The front sprocket and tensioner sprocket have been replaced, so thats no problem...
    Thanks
    illinois
    743
    hello -check micrfiche from bike bandit!! if possible
    Jul 2004
    Here
    126
    Thats it!!
    Whats the odds, you reply to my post on my B-Day. Of which I turn 32 and my name is also jason.
    yeah I know...who cares.
    Thanks
