Results 1 to 11 of 11
Thread: 350x wheel bearing #???
    na
    5,702
    Does anyone know what front wheel bearing #'s work on an 85-86 350x? I'm looking for the standard generic #...example "6203-2RS" I need to know what industry standard # they use on those. Thanks in advance.
    Proudly NOT a member of
    "Team on the Teat"
    mean350 is offline Just Too Addicted Arm chair racerJust too addicted
    uniontown pa
    472
    just go to a parts place and say *Edited* need baerings for a 350x. simple as that dont need part numbers lol
    na
    5,702
    i know that.my thing is is i have a supplier i get bearings from for a fraction of the cost if i had a industry bearing number.you keep paying their prices .i am not.i am checking for a friend that is why i dont have a number.
    "Team on the Teat"
    uniontown pa
    472
    what kind of bearings do you need? all balls?
    uniontown pa
    472
    i mean the brand
    na
    5,702
    i dont have time to order bearings.i am looking for the part number of the bearing.wheter it is all balls.pivot works whatever.every bearing has a (industry standard number on the grease seal of the bearing. it reads(6208-2rs or 6203-2rs or 7303-2rs,what have you.) every bearing has one of these numbers on it. if i can get that number,i can run 2 blocks down the road and get the bearings i need. that is what i am looking for.they would cost me 3 bucks each instead of 24.99 plus shipping and a 5 day wait.i need them for trike fest.that is why i need this set of numbers if any one knows them.thanks
    "Team on the Teat"
    Mar 2005
    Underwood North Dakota Tiger country
    1,055
    Moshman I will be back in 15 minutes with those numbers I have a loosse 86 350 hub I will check it out for you
    Trikes currently owned
    E.T. trike 150H.P. and climbing Pure DRAG beast
    85 250r project
    illinois
    743
    Thumbs up
    hi im not sure if this helps but here goes -dennis kirk-1-800-328-9280-
    rear -part #-(12-1619) $---33.95
    front-(12-1618)----$ 16.95 those are for a 85-86 350x
    Rittman, Ohio
    6,276
    I use the DennisKirk catalog as a rference which translates their PN# to an mfg part number. The 85-86 350X front wheel bearings are 6302-2RS . The first four digits are the bearing size and dimensions and determine actual fit. The 3 digit suffix pertains to if its sealed, what the seal is made of, and I dont remember what else.
    na
    5,702
    thanks.guys.those are the exact numbers ineeded tim sr.tripods stuff is broke before we get there
    "Team on the Teat"
    Rittman, Ohio
    6,276
    Quote Originally Posted by moshman355
    Its a trike, dude!
