Results 1 to 13 of 13
Thread: HELP Can I fix this Coil???
    Mar 2005
    Underwood North Dakota Tiger country
    1,055
    I was working on the Tiger today and when I went too start it no spark. so I tracked it down too a broken plug wire . but this type coil does not screw in its fixed in too the coil at the factory . I know I can buy one but would be late thursday or friday before it shows up. any way too fix this till after Trike fest
    Trikes currently owned
    E.T. trike 150H.P. and climbing Pure DRAG beast
    85 250r project
    so what are you gonna do now dale? could you possibly solder another one too it and tape it up????????????
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    Use a different coil off of a Honda or somethin
    Aug 2004
    Ab Canada
    4,368
    Is it epoxyed in? If so you can cut the expoxy with a Knife and work the old wire out...put a new one in and hot-glue/epoxy it in..
    1985 Tri-Z-
    Mar 2005
    1,055
    I will order a new one I tried too use a bosch set -up (standard can am ) which is a lot differant. but too no avail so tommorrow we cut this up and see if we can fix the kokasin type
    85 250r project
    Howdy's Avatar
    Celina, Ohio
    10,079
    Bro, shoot me a picture of it. It possible I have a coil at the shop. Also, 6v or 12v?
    Howdy
    Mar 2005
    1,055
    I don't have a voltage system diagram its a cdi to a coil only doesn't say if it's 6 volt or 12 volt I tried 5 differant honda coils too no avail so I know this is a good coil just a bad wire will be slowing cutting in too this and fixing it
    85 250r project
    Mar 2005
    1,055
    I forgot the pic also this is smaller than a honda coil. a honda will not bolt up correctly
    85 250r project
    May 2005
    Dorset United Kingdom
    1,408
    That looks just like a Z coil. Ill go grab a pic of mine for you, This coil came from Howdy.
    85 Tri-Z "Rumble Bee"
    85 250R "Red Rocket"
    83 200X "Flat Tracker"
    May 2005
    1,408
    Mar 2005
    1,055
    yea I have coils from honda's yamaha's and suzuki and kawasaki here None is close too this and they wouldn't work I cut back the plastic resoldered the plug wire and epoxied it in place waiting on it too set up keep your fingers crossed
    85 250r project
    Mar 2005
    1,055
    coil is fixed it's not pretty but works
    85 250r project
