Results 1 to 8 of 8
Thread: 350x brake caliper question
    Jan 2005
    RI
    2,530
    I ordered all new seals, dust seals, pins, bushings, and pistons for my 350x caliper. I also ordered a new master cylinder so i should be all set.
    Only problem is that i cannot remove the pin that the caliper slides on from the caliper. its the one that has threads on it for the nut so you can bolt the holder and caliper together.
    its number 11 on this page...http://houseofmotorcycles.bikebandit...me~ATC350X.asp
    ive tried head, screwing the nut on and using an impact, which just stripped the threads on teh nut. Any help would be much appreicated.
    thanks,
    mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Feb 2003
    California
    623
    I'm not familiar with the 350x caliper but are you saying that the nut holding it on is frozen and won't move or the pin is frozen in there?
    Aug 2004
    Newcastle NSW Australia
    128
    I'm just partway through rebuilding a 350X caliper, I'm documenting the whole lot so I can put together an article on how to, It sounds to me like you are attacking the wrong bolt, the bolt that holds the caliper to the bracket and acts as a slider has an allen headed part at the top and screws in to the bracket, you most probably wont get this slide bolt out easily, you will have to gently heat the caliper and the bracket and slowly work it to get it out. Once you remove the slide bolt the caliper should come away from the bracket.
    Hope this answers your question.
    Jan 2005
    RI
    2,530
    its the pin that sits in the caliper. one side is threaded and that nut bolts onto it to hold the caliper bracket (bolts to the forks on). (i can get the nut off fine...)
    I am trying to get part number 11 out of the caliper body to replace the boot (number 14) and grease the hell out of it. I already have a new number 11 on the way so its no big deal if i trash it.
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Jan 2005
    RI
    2,530
    i just got it out... a pair of vice grips, some heat and some pulling got it done...tons of junk in there
    mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Jan 2005
    RI
    2,530
    so the piece that i pulled out...there is an oring in there? Are you talking about the front brake caliper? Or the rear brake caliper and the piston rod is part of the parking brake?
    On a parts diagram at bikebandit, which number is it? I cant figure out what you are talking about. I have the same problem not being able to bleed my brakes. I bought a brand new master cylinder and am rebuilding the caliper because of it...
    thanks
    Mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Jan 2005
    RI
    2,530
    john i see that, but the front caliper is different, at least on the 85. There is no piston shaft and i cant see where it would go on thefront caliper. its not that i dont believe you, its just that im lost as all hell as to where it would go
    mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Jan 2005
    RI
    2,530
    hahah ok...i was like i have no idea where that oring could go...
    thanks for your input, hopefully ill have nice front brakes again after all of my parts come in.
    Mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
