Thread: anybody ever
    East Peoria IL
    99
    anybody ever
    put an 83 or 84 250r shock on a 200x?
    i guess the 200x shock is about 12.25 inches in length and the 83 250r is about 13.00 exactly. seems like it'd be a better shock and it'd sit it up a bit higher. but the 84 is like 14.00 almost. anybody think it'd work?
    NE. Ohio
    484
    Quote Originally Posted by SET THE STAGE
    Interesting, If your measurements are correct 13" might work.
    So, does that mean you dont want the mount?
    East Peoria IL
    99
    i might still buy it. i'm just short on cash right now. and i've applied at 8 different places and no calls so far!!
    as soon as i get a job and some extra cash i'll for sure buy it. but according to Works' shock guide (it has the lengths of almost every shock made) it's just a bit longer. and seems like it'd be a lot better of a shock
    Muddys mounts are amazing!
    84 Honda Big Red w/plow
    85 Honda 200X
    88 Honda CR 125
    86 350x(in process of building)
    :trikesown :Beerchug :trikesown
    PA
    3,515
    i put a r shock and linkage on a 250x but you need to use the linkage or it will be real soft
    WWW.HREATV.COM
    CUYAHOGA FALLS, OHIO
    1,242
    Yeah
    It will work with some very minor adjustments. I put a 200x or my 84r. The bottom mounting bolt diameter is different. But it will work
    3-85 ATC 70
    86 ATC 250R
    86 WETBIKE
    01 KX250
    2011 KAW SXR800- 35YR EDITION
    05 HERITAGE/SPRINGER/SOFTTAIL
