Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 34
Thread: how to time a 8 hp briggs engine
    Jul 2004
    minnesota
    689
    how do I time a 8hp briggs engine, thats all i need to know?
    thanks hotroddal
    my trikes:
    1983 honda atc 200x-k&n filter
    2002 yamaha raptor 660r, yoshimura slip on, prm grab bars
    1978 chevy nova, 454 v8, bds blower, 150hp shot of nitrous, full roll cage, a real power house.
    1991 chevy s10 4x4 350v8.
    1986 250sx
    YES its fast NO you cant ride it.
    Aug 2004
    Ab Canada
    4,368
    You talking cam/valve timing? Theere should be a little mark on the cam-shaft gear and the crank you have to line up when the piston is at TDC.......with the flathead brigs anyways.
    1985 Tri-Z-
    Jul 2004
    minnesota
    689
    is there any way to tell if your engine jumped time or is that possible for it to jump time.
    my trikes:
    1986 250sx
    85ytz250n is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    Waynesboro, MS
    338
    It would have to have the teeth on both the crank and the cam worn to almost nothing. The timing marks have to be lined up, the timing mark on the crank will be tdc and the timing mark on the cam will be bdc, now all that means is the marks will be like this : I have never seen a 5hp jump time, havent worked on but a couple 8hp so I cant tell you 100%. I hope this helps.
    Barry
    There are no stupid questions, but there are alot of stupid people out there that ask questions.
    None of us are capable of screwing things up as bad as a group of us.
    "NON SIBI, SED OMNIBUS"
    NC
    13
    i've never seen a briggs jump time.
    has it thrown a rod before?
    you may have a stuck valve , briggs is notorious for valve sticking.
    Jul 2004
    minnesota
    689
    it has never thrown a rod before, im not sure if it has a stuck valve , is there a way to check if the valve is stuck?
    my trikes:
    1986 250sx
    Apr 2006
    Waynesboro, MS
    338
    You can pull the head off, and turn it over by hand. Unless it has the OHV and then you would have to ask someone else, I am more knowleadgable about the older briggs. Pulling the head is no big deal, just remember which bolts come from which hole cause there are different lenghts. What are the problems you are running into with this engine that makes you think it jumped time?
    Barry
    Mar 2004
    457
    make sure the key on your flywheel isnt sheared or partially sheared, that will make the magenents on the fly wheel pass over the armetuer at a different time, therefore jumping time
    RIDE IT LIKE YOU STOLE IT! AND NEVER LOOK BACK, THEY ARE TOO FAR BEHIND TO SEE!!
    Id rather have a sister in a WHORE HOUSE than a brother in a FORD!
    Jul 2004
    minnesota
    689
    what problems I am having is that the engine wont start it has great spark, and is backfiring and spitting gas out the air intake on the carb, so i thought it may be the timing that is off.
    my trikes:
    1986 250sx
    NC
    13
    flywheel key is broke and the ignition timing is 180 degrees out.
    pull the flywheel and put an new key in and make sure the flywheel nut or starter clutch is real tight or it will just shear the new one.
    Jul 2004
    minnesota
    689
    thanks for the help, i will go and pull the flywheel and see if the key is sheered.
    my trikes:
    1986 250sx
    Aug 2004
    Ab Canada
    4,368
    Sounds liek a stuck intake valve to me....i have NEVER seen a brigs Shear a Flywheel key, im sorry but unless your running on alky, it dont happen....lol
    1985 Tri-Z-
    Jun 2006
    canada
    26
    hi. it could be the flywheel key and they do shear if a heavy load is put on right away it causes the flywheel to keep going so it shears. and yes all engines can shear the flywheel key. if its backfiring and spitting gas its the key. ive had that problem before and i put a new key in and it started right up
    Jul 2004
    minnesota
    689
    well I took that mesh screen off the flywheel and that aluminum piece that it screws to off the flywheel, and it doesnt look like the flywheel key is sheered, is it possible to tell if it is sheered just by looking at it or will I have to pull the flywheel?
    my trikes:
    1986 250sx
    NC
    13
    they are bad for imprinting a small score on them.
    i'd pull the flywheel to check it out.
    i've had many do this.
    if it pops and spits bad after starting you'll have to do a valve job.
    most likely a burnty valve then.
    hope you find the problem
