Thread: '86 T3 problems update
    250SX's Avatar
    250SX is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Raymond, MS CSA
    310
    Jeb, I made "some" progress as far as narrowing down my problems, I think. check out this link and tell me what you think (so I ain't gotta retype it).
    http://www.3wheeler.org/vb/showthread.php?s=64134eaf4169895564ef7c3c54cbb883& threadid=3254
    Anyone else that has any ideas I'd appreciate hearing from.
    thanks,
    '8? ATC70s
    '8? ALT50
    '8? YT175
    '83 ATC185S
    (3) '85 ATC250ES
    (5) '85 YTZ250
    (2) '85 ATC250R
    (5.5) '86 KXT250
    '86 YTZ250
    '86 KXT500
    '86 ATC350X
    '87 KXT250
    '87 ATC250SX
    and a couple of Mancos
    RichinMO's Avatar
    RichinMO is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2002
    Waynesville, MO
    321
    Ok, so if you was to put the old carb setup back on, it would run fine? Thats what I would do. If it runs good with the original setup, that would eliminate the stator/electrical mystery and then you would know it was strictly the carb causing your problems.
    1985 ATC250ES
    1985 ATC250SX
    1984 ATC200S "Little Red" - Trailer hitch, Hondaline: Front and Rear Racks, Cooler Rack, Tripmeter, HL Grille, Rubber Footpeg Covers, Mudflaps.
    1985 ATC70
    2008 CRF230L - Dual Sport
    2016 TRX500 Foreman Rubicon Deluxe
    250SX's Avatar
    Raymond, MS CSA
    310
    I wish it was that easy. It runs like crap with the old setup too now.
    May 2002
    Texas
    2,670
    Hi Dan,
    I would follow Mik6's advice that he posted on your board. He makes some good points. (that way I don't have to re-type either... ;-) ) I think it could be stator going bad on ya, but you can't rule out the carb situation either.
    Let me know what ya find out...
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
    250SX's Avatar
    Raymond, MS CSA
    310
    how do I test the stator?
    '8? ATC70s
    '8? ALT50
    '8? YT175
    '83 ATC185S
    (3) '85 ATC250ES
    (5) '85 YTZ250
    (2) '85 ATC250R
    (5.5) '86 KXT250
    '86 YTZ250
    '86 KXT500
    '86 ATC350X
    '87 KXT250
    '87 ATC250SX
