Results 1 to 15 of 26
Thread: 86 250R reed cage options
    Rancho Cucamonga, Ca
    228
    All right, I've had my carb modded, my cylinder bored and ported, a new esr pipe, silencer and flange installed. Do any of you have any experience with the esr reed assembly? I think my next upgrade will be a v force or a rad valve or the esr set up. Any thoughts on which may be better for me. Dune and desert riding at lower elevations mostly. The esr set up is not on their website but I hear is real nice using carbon reeds. Any input is appreciated. Thanks....Dove.
    own:
    1986 250R- ported polished, carb mods, Esr atc-5 pipe and silencer
    1986 250R- mild porting, carb mods (Clean!)
    1985 350X- all stock (super clean!!)
    1985 350x- desert project in the works
    1986 250sx- Mostly stock
    1985 200x- (pretty clean mostly stock)
    1985 Yamaha tri zinger 60
    Jan 2005
    Great Bend
    704
    you might give www.1dirracing.com a look see. i haven't tried them yet but my T3 is getting their reed cage set up as soon as its ridable
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    +2" Miltech swingarm
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    +1" Miltech swingarm
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    Phoenix, AZ.
    6,719
    I can't comment on the esr or v-force setups but, you've seen my R run and I've for a Rad Valve on there if that helps at all. I should have told you to take a spin on it.
    228
    Quote Originally Posted by Dammit!
    Yup. Your's is what I'm aiming for at Glamis next year That's what I was thinking of running until I heard about the esr. Your's hauls!
    own:
    Phoenix, AZ.
    6,719
    I'm gonna have to make mine a little faster. I have people gunning for me now.
    I finally got a good set of paddles. When I bought my air compressor the guy threw in a practically brand new set of 20x10 8 paddle haulers. I just have to get some rims for them. No more crappy Sand Sharks!
    breastman569 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2005
    Tucson & Mesa, Arizona
    272
    a lot of guys that i deal with here in a town that do custom work all say to get the rad vavle thats the set up they like the best.
    Jan 2004
    Palmetto,Florida
    2,300
    Rad Valve,Ram Valve....... YUK !!!!
    When i get back to work i'll post the Honda part # for the CR Reed Cage........
    You Will LIKE IT !! Along with the Paul Turner High Rev Pipe..........
    It's The Best Set Up !!! Tested,Been There,Done That !!!
    "07" DR650 Suzuki Dual Sport
    3leggeddog's Avatar
    Nov 2004
    i like my v-force reeds.they are a wicked bolt on.that and the pt high rev,wow,what a combo.i think i had a drag with brapp at tf.i didn;t run many cause my motor is comin apart in the bottom,but i did spank a 450,and i think,maybe brapp,and i ran.
    228
    Can you still get paul turner Hi rev pipes? I went with the Esr, I heard it was very good. The esr reed set up looks similar to a haonda cr set up, billett with or without a reed spacer and carbon reeds. I'm leaning rad valve but considering esr. The guys at Esr say they have tested their set up and a rad valve and say they got better performance from their's. (of course) It looks like aa tricked out Cr unit. Thanks for all the feedback guys.
    own:
    Anaheim, CA
    517
    dont know too much about this but ive heard the rad valve is limited to your stock carb size. so that may be a problem unless you buy the specific valve for the size carb you are using. i personaly like the v-force but have never seen the esr setup.
    83 250R
    91 CR125R
    3leggeddog's Avatar
    Nov 2004
    you can actually have more choices with a rad valve.they have a rubber boot/sleeve that is easy changed for bigger/smaller carbs.
    you can still get pt pipes.i love mine,i have had them both,and both are great.dunno about esr stuff.i have heard alot of good things though!!good luck
    Anaheim, CA
    517
    i know they have different boots but i was reffering to the size of the valve opening (bore). and im not even sure if its true or not just repeating what ive heard. lol sorry for the confusion
    83 250R
    91 CR125R
    3leggeddog's Avatar
    Nov 2004
    no confusion bud,i know whats going on!!!,lol,j/k.
    good point,but then wouldn't all of them be limited?i like the rad valve's,back in the day thats all there was,boyseen,or fmf.
    Anaheim, CA
    517
    im sure its better than stock. and if they had one for my aircooler id snatch one up but for me the only choice was the v-force since the boot on the rad valve is angled, and the v force still uses the stock intake. do they make a rad vlave for the tri-z?
    83 250R
    91 CR125R
    Aug 2002
    New York
    1,098
    I have run the CR cage in the past...it's OKit works fine, but I don't like that it is plastic. I run Rad valves now. On my ice bike, I run a 40.5-42 mm taperbore carb. I then took a modified KX500 Rad valve (estra 2mm of opening on the motor side of the cage) and honed it to match the carb. It is a perfect port job that matches the carb exactly.
    Some say that the ESR/ V Force (same thing in my opinion) is better on bottom end for snappy power because the petals need to move less to get the same flow. I can see that, but the Rad Valve is a fully portable, grindable, flow monster. To compensate for the larger reed and longer distance of the reed swing, I use carbon fiber reeds. Very light and very stiff. Snaps back nicely. Very responsive. More for top end, and less restrictive than the stock setup.
