Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Thread: 86 250R reed cage options
    Rancho Cucamonga, Ca
    228
    Good info. Esr says theirs is ported already. Just saw some photos of it. I'm leaning that way now. Since no one has tried it yet maybe i can give some good feedback.
    own:
    1986 250R- ported polished, carb mods, Esr atc-5 pipe and silencer
    1986 250R- mild porting, carb mods (Clean!)
    1985 350X- all stock (super clean!!)
    1985 350x- desert project in the works
    1986 250sx- Mostly stock
    1985 200x- (pretty clean mostly stock)
    1985 Yamaha tri zinger 60
    Jun 2003
    englishtown NJ
    2,676
    I use a 86-98 cr rad valve and a 1/2 spacer, it fits my 39mm carb perfect.
    Phoenix, AZ.
    6,719
    When I was shopping for a new cage I asked about them at a couple different places that carried both the v-force and the rad valve. One of them was Trinity Racing but I can't remember who the other one I was. Anyway, They both said almost the exact same thing. Top end power will be virtually identical but the rad valve will hit a little sooner and the delivery is smoother. Take that for whatever you want. I usually don't put much stock in what these shops tell me but it was so similar that I assume there must be some truth to it.
    I installed the rad valve at the same time as a new carb so I can't comment on what kind of difference it made over a stock cage with boyesen reeds. The two of them together made a good difference though.
    atcsteve's Avatar
    atcsteve is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2004
    arizona
    157
    The pryamid cage is one of the best!!
    85 250r drag bike
    87 trx 250r ESR big bore
    Anaheim
    1,270
    now, withmy tuning... 52 pilot 165 main!! thank god!!! my bikes back into good shape.... but i did install a vforce reed valve, and i have to admitt the VForce 3 with snapless reed design, and no screws.... i have to admit i like it!!! they say and dyno's read a 5% +INCREASE with Vforce reeds ALONE
    86 ATC 500R the duner..
    1985 ATC 250R Bone stock!!
    1985 ATC250R mx/duner
    1986 TRX370R MX/Duner
    Phoenix, AZ.
    6,719
    Quote Originally Posted by RideRed250R
    You better do some WOT plug chops. 165 main for what you're running sounds lean. I'm running a 178 with a smaller carb and a smaller bore. I bet that 52 pilot helped a ton though.
    Fresno Ca
    2,695
    Pryamid will be what my R will have on it when i get it. Duncan racing sells them and ive herd NOTHING but good things about it.
    Jun 2004
    potsdam ny
    1,227
    ok, ive tried the v-force, rad valve, ram valve, ported ram valve with stuffer removed, CR, ported CR, stock, ported stock and the ESR reed cages. from experience with all of the cages, i would rate the ESR at #1 and it is definately not the same as a v-force, the ESR has huge petals and it is all billet and the carb side has knife-edged crosshairs to strighten the flow, extremely high quality, second was with the ported-to-hell ram valve with stuffers removed, it cranked, but when i put nitrous to my R, i blew the reeds out the air filter(dont ask me how, idk), and third was the v-force 3, it seems restricting to me, i still run it on my rider, but the motor doesnt seem as free to rev as the others
    Aug 2002
    New York
    1,098
    Larger bore motors have less velocity, so they use smaller jets. I went from a 190 (warm weather) 200 (cold weather) on my bike to a 175 main in cold weather when I went from the 250 to the 330. I run a 40.5 PWK. It sounds counterintuitive, but it's true.
    Phoenix, AZ.
    6,719
    Quote Originally Posted by ChrisD
    Yeah I thought I'd seen someone post that before after I said that. Still. Better safe than sorry.
    Anaheim
    1,270
    yah i will do so... right now the bikes BACK down apart cause iam doing the tranny the way i want to... ill be up in pismo the 23-26 with it... so far my trans will be a dune override cut 1-3 HEHEHE means i can down shift to!!! GOD BLESS DMR!!! once thats all said and done (probably weds) ill go street tune it again LOL....no but seriously..
    Adam
