Thread: Is it Bad or Not ??? Store Trike's in the -
    Oregon
    2,471
    Can you Store your 2 stroke's ATC'S in the Up Right Position , - (Standing up) Resting on it's rear tires and Drag bar
    Is their any Problems , or can this Damage the ATC's engine or ?
    Post your thought's ...
    phreakboy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2005
    Coatesville,PA
    358
    It is fine to do that, but you need to make sure your gas is off, and after you set it down you should let it sit for about 10 mins before starting it.
    1971 ATC90
    1984 200s
    1983 Autox
    1985 200x
    198? Yamaha 125
    (2) 1985 250sx's
    1974 Trail 70
    1991 Honda Cub90
    1974 Yamaha 125 Dirtbike
    1972 Kawasaki 175 Dirtbike
    (2) 1980 Chrysler Sno-Runner
    (7) 85-87 Toyota Mr2s
    (2) 1985 Dodge Ramchargers
    1968 Mustang
    1972 Beetle
    2004 Dodge Ram 1500 HEMI
    Sep 2005
    Northwest Ohio(Forest)
    974
    ive also wondered this. And what about 4 strokes?
    '86 200x
    Apr 2005
    Coatesville,PA
    358
    It doesnt hurt either 2 or 4 stroke bikes, like I said just turn the gas off and be sure to let fluids settle before starting.
    1971 ATC90
    1984 200s
    1983 Autox
    1985 200x
    198? Yamaha 125
    (2) 1985 250sx's
    1974 Trail 70
    1991 Honda Cub90
    1968 Mustang
    1972 Beetle
    San Diego Ca.
    12
    Store it how ever you want to, upside down if that is what you have to do.. 2 stroke a 4 stroke, its all good. Turn them back upright, check all the fluids......gear case and coolant if you are h2O cooled and call it good. If you are going to store a bike for any length of time you should put some oil through the fuel, I use Marvel Mystery Oil, run it for a bit, drain the tank, fog the tank with WD40 or whatever else you like to keep rust away (metal tanks) and call it good. The good thing about storing a wheeler off its tires is you have no weight in the tires (flat spots) or suspention (sag)....if you have it. This is what I do and I have never had a problem.
    F.J.
    Nov 2001
    B.C.
    933
    As for 4 strokes...Hondas 185-350s anyways...once you've put them back on 3 wheels, be sure to cycle the engine over quite a few times to refill the oil pocket in the head. Standing the machine on it's end empties this pocket. This pocket supplies lube to the cam lobes and without it the cam will gall itself in no time. So, with the kill switch off, kick or pull the engine over to send an adequate amount of oil through the system and fill the pocket. Chewed cam/rockers/heads are an expensive fix!
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
