Results 1 to 15 of 18
Thread: My Mazda has a bad hesitation
    springville, PA
    6,185
    ok the basics------ 1993 Mazda B2200 (carburated) stock everything except plugs, plug wires, air filter, and distributor cap.
    Now the tricky part. There is only one spot in the RPM range where it hesitates (2500 when cold 3000 when warmed up). Now it will only do this WHEN IN GEAR. If I have it in nuetral and rev it there will be no studder/sputter/hesistion but if I put it into gear and bring it up into the RPMs it will act up. Also I can just push the throttle down and it wont be hardly noticable. (also the hesitation isnt like a nice little bog it is very violent like when you leave your vehicle in gear and let it get down to like 600 RPMs.)
    So far i have been told it could be the accelerator pump or it might not be advancing the timing. Any Ideas?
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Eastern Long Island
    1,688
    Check all your vacum lines for cracks or leaks. I'd also try replacing your fuel filter.
    Lots O Trikes!!!!!
    Mar 2005
    overton, PA
    5,257
    drive it off a cliff and buy m7y chevy lol or quit riunning biodiesel in a gas motor.
    Mike_Ham_250R's Avatar
    Mike_Ham_250R is offline Even team-red-rider is cooler then me. Arm chair racerJust too addicted
    Pennsylvania
    1,058
    Quote Originally Posted by brapp
    LMAO!
    Maybe you have to rejet HAHAHHA.
    -Mike
    springville, PA
    6,185
    hey josh you hook me up with a cheap diesel truck and I'll drive it off a cliff
    Nate
    R.I.P HRR
    Aug 2004
    Nampa, Idaho
    1,245
    How many miles does it have? It could be a bad cap or maybe a worn distributor.
    springville, PA
    6,185
    just rolled over 101,000 miles.
    Nate
    R.I.P HRR
    Minnesota
    790
    Have you cleaned the carb recently? I would atleast try running some SeaFoam or something through the gas... My friends old carburated accord had the same problem and it turned out to be a vaccum leak around the carb or intake... it did have a very slight hesitation in neutral tho, however much more detectable when in gear. Exhaust seem blocked at all? I'm assuming you changed the rotor when you did the cap?
    -86 Polaris Scrambler 250r/es - sold
    -84 200es Big Red
    -92 Ski-Doo Formula Plus 583 -88 Safari 377 -68 Super Olimpique 299
    -87 Jeep XJ 5" lift/many other mods-sold
    -89 F-150 4" Lift/33s
    -90 Acura Integra - '83 Mustang 5.0 convertible (the new project)
    Ask me about custom cut decals!
    Feb 2005
    Canada
    663
    What do you expect? it is a Mazda.
    1984 Honda 250R
    1985 ATC 250SX
    1985 Tri-Z 250
    1983 Honda 250R
    1986 Honda 350X
    1983 Yamaha Tri-Moto 175
    1983 Honda Big Red 200
    1981 Honda ATC 110
    springville, PA
    6,185
    Quote Originally Posted by Yamaha Tri-Moto
    Yeah yeah yeah, I guess i could have gotten a F150 or something and got a decent 15mpg but got greedy and wanted 26mpg
    Powertrike there is only one loose hose and it runs from the exhaust manifold to the air intake? Thats how it goes but I dont understand WTF its supposed to accomplish. I dont suppose if I sprayed carb cleaner around the carb it would show a leak like spraying it around the intake on an ATV right?
    I'll try some seafoam since there is alot of linkages I have to take apart to open the carb up.
    Nate
    R.I.P HRR
    NC
    13
    be careful spraying the cleaner. many a car has been burnt up by checking for leaks with carb cleaner.
    i'd use WD-40 it's safer and will have the same effect.
    the vacumn line going to the exhaust proably goes to the egr valve.
    if it's completely unhooked plug the line and test drive it.
    another thing to check is the fuel filter.
    you should have one on the the engine and could have one located on the frame under the truck.
    hope this helps?
    springville, PA
    6,185
    yeah the line is hooked up but its loose so i should probably tighten it up, and I'll be sure to check the filter. thanks
    Nate
    R.I.P HRR
    Jan 2005
    Oklahoma City, OK
    603
    I had a truck that had a very similar sounding problem. My 87 chevy blazer was throttle body fuel injection so it was a little different, but still similar. When the truck was in gear, it would sputter at a certain rpm range, before and after that "spot" it was fine, and in nuetral it was also fine. It ended up being the EGR valve. Not knowing anything at all about mazda's, I dont even know if they have an egr valve, still worth looking into though.
    Its easy to test too, just find it (its a round diaphram that you can put your fingers under and reach up push the valve), push the valve, if it either doesnt move, is very hard to move, sticks, or doesnt come back down at the same speed it went up, your egr valve is probably bad. You can either replace it which is an easy fix, or you can jimmy rig it If you cap off the vacuum line going into the egr with a machine bolt, it will force the computer to use a preset value, and it wont use the egr. It will fire the check engine light every once in a while though. i recommend the first method, but I have seen the second work just as well, lol.
    If there is no egr or that doesnt take care of the problem, try checking the distributor like mentioned. Sometimes they get worn at the bottom, a good way to check is to very gently push and pull at the top, see if it moves at all or if there is any play, if there is that will mess up your timing. other than that check the vacuum lines for leaks.
    If none of those things work, sell the truck and buy a chevy good luck man
    85 Tecate, 2002 Honda 300EX, 83 & 84 250R, a bunch of honda 4 strokes from 90 to 200cc, a klt 110, ytm 200, polaris 250 cyclone, '05 Roketa 125 (cheap chinese pitbike to beat on), '69 Scrambler 6x6, and a 52 John Deere B (hey its a rowcrop narrow front, that counts right? )
    Trike Fest 06 and 07 Survivor, hoping to make it to 2010
    springville, PA
    6,185
    yes there is indeed an EGR valve so i'll check that hopefully today when i get a chance. And we are actually looking a 3500 chevy diesel so maybe the mazda is gonna end up going bye bye anyway.
    Nate
    R.I.P HRR
    Jan 2005
    Oklahoma City, OK
    603
    chevy diesel would be pretty cool, is it a 6.2, 6.5, duramax, etc? If you get it post up some pics!
