Thread: need help finding parts site...also..update.
    panama city
    22
    looking to buy a few new parts for my 1984 yamaha tri-moto 125
    i need to buy piston, rings, pull start, and a few other nic-nacs.
    does anyone know of a site specifically for yamaha parts....kind of like beatrice cycle...except for yamaha? thanks
    steven
    update...got 2 yamaha 125s. ones 84..the other 85. pulled both cylinders. one piston is definetly fried. the other may be salvageable, but would rather buy new ones. rings=goners also. broke elevendy hundred cooling fins off of one of the jugs, but the other should be usable. one head looks ok on the inside, the other looks alot cleaner , but has what i guess would be pressure faults? not sure, will have to emery cloth them down a little or something similar in nature to see how deep they go. in the process of changing over choke buttons, lights, front racks ...and possibly rear bearings to the good bike from the donor. im also, trying to figure out if either one of the 2 stroke oil pumps is good, guess ill have to wait until i get a pull start to test that one though.
    all for the updates for now.
    thanks
    steven
    Most of us learned to ride on pedal tricycles......it would only make sense that we returned to these urges....only on a whoop ass level.
    Jan 2005
    RI
    2,530
    a lot of people block off the oil pumps and just premix...seems a lot safer than trusting a 20+year old pump
    www.bikebandit.com has yammie parts
    mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    panama city
    22
    the pump doesnt look to be in bad shape at all. its also covered in a sealed chamber. im going to test it before i use it most certainly, but i dont think it should have any problem at all.
    smackkk's Avatar
    smackkk is offline Check my feedback before dealing with me. Arm chair racerNew to the board
    arkansas
    109
    How Do You Block The Oil Pumps..?
    Mar 2005
    Underwood North Dakota Tiger country
    1,055
    I had one and the guts was removed so it wouldn't pump then dis-connected
    Trikes currently owned
    E.T. trike 150H.P. and climbing Pure DRAG beast
    85 250r project
    holmstrom is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2005
    bryan ohio
    221
    I took the gear out when i had the case off and put in new crank seals.
    2 125 yamaha tri motos
    1 yt175
    1991 blaster
