Results 1 to 15 of 15
Thread: ATC 70 jetting with Uni filter
    Jun 2006
    Anchorage, AK
    23
    I have an 1979 ATC 70 and just stuck a straight "UNI" filter onto the carb and did away with the airbox - at least temporarily. Of course now it's not running quite right as it's lean.
    What's the stock jet (main) on that little carb, and what should I go to? I assume I need to mess with the Main...
    Any and all info would be much appreciated. Also, does anyone know where to find the little shift indicator (white with red ridge for indication)? I don't see any on DR ATV...
    Thanks!
    Minnesota
    784
    Where does the motor start running bad? Anything over 1/2 throttle? I've got a similar set up on a 70, clamp on UNI filter plus a cobra pipe, and anything over 1/2 throttle it starts missing, putting the choke on helps alot. Stock main jet according to clymer manual is a 58. I'd suggest going up in main jet sizes until problem goes away. Did it run perfect before the filter swap?
    Gear indicator should be available from honda, atleast it was around 2 years ago when I bought one.
    Jun 2006
    Anchorage, AK
    23
    Thanks for the comeback! It wasn't running great before as there was tons of rust chunks blocking the lines and the carb. So I cleaned all the out, put a carb kit in it, and just stick the uni filter on for kicks. I still have the stock box and it's fine. It starts cutt'n out and backfiring through the carb slightly if I punch it over 1/3 throttle. If I ease it up slowly, it'll rev up ok...but not great.
    I haven't tried the choke thing yet, but I will. I'm sure it'll be much better w/ the choke on. Where's a good source for jets??
    Thanks...
    Minnesota
    784
    For jets try any local ATV/snowmobile repair shop, or www.denniskirk.com
    Rittman, Ohio
    6,276
    I would be looking at the points, condensor, and point gap which controls your ignition timing. I doubt that carb adjustments are causing anything that drastic.
    Ive taken the airbox completely off an ATC70 for test purposes and it still appeared to run decent.
    Jun 2006
    Anchorage, AK
    23
    I have some jets coming from Dr ATV (62, 64, and 68). The points and ignition are brand new, and the only that changed (to cause this drastic difference) was to completely remove the airbox and stick on the straight filter.
    I guess we'll see!!
    Jun 2006
    Anchorage, AK
    23
    Just to add some closure. I never did play with the jets, although I have them here if I want to. I cleaned and rebuilt the carb, and put the stock airbox back on, with the needle clip on the middle position (I'm pretty sure that's stock).
    And... it runs AWESOME. Smooth, consistent, with the power you would expect a 70 to produce.
    When I get some more time, I'll start modding, in the meantime, I'm happy with stock consistency. And I have to get #2 all up and running for the girlfriend. I've got pink fenders on the way for it!
    Washingtons Crossing, Pa.
    2,977
    I went up to (I believe) a #64 when I put the K&N and Cobra pipe on my ATC70. I also moved the clip up one position richer.
    Minnesota
    784
    Wicked, did you try running it with the mods with stock jetting? How did it run? Also, raising the clip on the needle makes it leaner, lowering the clip makes it richer right?
    Jun 2006
    Anchorage, AK
    23
    Wicked, where did you find that rear grab bar? Or did you fab that yourself? I'm looking for something along those lines... And might have to whip out the TIG
    2,977
    Quote Originally Posted by AlaskanSD
    Its a PRM rail ..... you can get it from PRM-ATV.com.
    2,977
    Quote Originally Posted by hrc200x
    It ran like crap with the stock #58, way lean to the point it wouldn't run past 1/4 throttle from gulping too much air (if thats possible with a little peanut carb) and I cherried the header quick. Richer is down on the clip.
    Jun 2006
    Anchorage, AK
    23
    Thanks Wicked!!
    Nov 2011
    East Greenville, Pennsylvania
    465
    Ill also be putting on a pipe and a uni filter. Hopefully it will be good with a 64. So clip goes down on needle for richer also? that would raise the needle in the carb which theoretically would make it run richer
    1985 Kawasaki Tecate 250 with kx 500cc motor
    1985 Honda ATC 70 custom built with lifan 125cc
    1985 Honda ATC 70 custom powder coat slight mods
    1985 Honda 250sx
    Yamaha zinger 90cc 2 stroke
    1985 Honda 250sx custom green and black build
    1985 Honda 200x
    Miami,Fla.(305)
    808
    Yes clip down brings the needle up= richer
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
