Thread: Castle nuts.. interchangeable?
    Pennsylvannia
    1,147
    Well.. since I am not having much luck finding some rear hub castle nuts for a Tri-Z on eBay, I figured that some castle nuts from other machines might fit. Do you guys know if like a 350X, 250R, Banshee, etc etc. rear hub castle nuts will fit right on?
    Thanks
    Ben
    PA
    3,515
    yamaha (blasters and banshees and many more) use a smaller then normal nut.....im not up on tri-zs but i bet these would work
    WWW.HREATV.COM
    Rittman, Ohio
    6,276
    The reason your not finding them on Ebay is because auctioning something that is worth a fraction of the shipping cost is a losing battle for any seller. Go to bikebandit.com. They are $4.81 for a NEW one, so you can imagine why nobody would auction a USED one. Yes, Banshee, Warrior, and Blaster use the same castle nut. 250R does NOT.
    Pennsylvannia
    1,147
    I figured that, Tim. I see some strange, small parts on eBay from time to time though.
    Thanks alot for the info!
    any motorcycle shop should have them in stock all yamaha sport bikes are the same banshee,warrior,blaster,raptor,yfz
