Results 1 to 15 of 23
Thread: painting exhuast?
    Mar 2004
    Gettysburg PA
    498
    painting exhuast?
    I was wondering what the best way to paint exhuasts was. Im planning on painting my 86 ATC 250r head pipe and was wondering what works best. Ive heard of people powdercoating their pipes but never realy heard about how well it held up.
    My Trikes
    1985 250sx
    1986 250r
    Parting out 85 kxt tecate pm me with your needs
    PA
    3,515
    i just powder coated a 350x pipe and it looks great and seems to be holding up real well...it was powder from www.eastwood.com
    WWW.HREATV.COM
    crd00's Avatar
    crd00 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2006
    somewhere over the rainbow
    323
    Just spray your exhaust with some high heat paint and it should be fine. I painted all my exhausts with high heat paint and they all come out perfect and last a long time.
    WWW.FASTRACKZ.COM!! Totally dedicated to Atv's/MX/Sleds. Go take a look at the photoalbum and drop into the forum and say hello!
    PA
    3,515
    here you go found a pic
    WWW.HREATV.COM
    Pa.'s Highest City
    8,058
    Before you do anything you have to make sure it is cleaned. I've heard of some folks dipping them in muriatic acid first to get all the rust and other junk off of it. Personally I've always just wire wheeled mine to get everything off then paint them with a 1200 degree BBQ paint. they hold up well if they are properly cleaned first.
    Mar 2004
    Gettysburg PA
    498
    yeah im gona sandblast it first. i once tried spray painting the exhuast on my sx with like 500 degree paint but i gues the pipe gets hotter than that cause it started smoking real bad and smelled horrible for a while till i blasted it back off. So i deffanitly dont want that happening agian.
    My Trikes
    1985 250sx
    1986 250r
    PA
    3,515
    eastwood also sells heat paint in 4 or 5 colors and its good to 1200-1500 degrees
    WWW.HREATV.COM
    CorbinKale's Avatar
    CorbinKale is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2005
    NE Texas
    179
    Quote Originally Posted by chris200x
    That is EXACTLY what I do, too. The 1200 degree paint forms a ceramic finish when cured, just by running the engine and cooling according to directions. Cheap and convenient with good-looking, lasting results.
    CPSC: Pissing in the gene pool, since 1973.
    Aug 2005
    michigan
    125
    iv heard that pj1 works really good on pipes
    83 atc 200
    86 lt250r quadracer
    crd00's Avatar
    Feb 2006
    323
    Corbinkale, is the 1200 degree paint in celcius or ferenheight? Because I have bbq paint and its 648 degree celcius but 1200 degree ferenheight
    Aug 2005
    Oregon
    490
    i use high heat bbq paint, looks good and lasts.
    CorbinKale's Avatar
    Dec 2005
    NE Texas
    179
    Quote Originally Posted by crd00
    Fahrenheit. I refuse to use Celcius. Fahrenheit gives me a greater degree of accuracy.
    crd00's Avatar
    Feb 2006
    323
    O ok, thats what I have, and I just wanted to make sure
    May 2005
    Southern NH
    1,489
    Yeah same here. If you go to walmart it comes in a couple colors. I used to have black but then I switched to silver as you can see in my sig....... Make sure you sand it down good first and put 2 coats and it will last quite a while
    "I have but one lamp by which my feet are guided, and that is the lamp of experience." -Patrick Henry
    NEW ENGLAND ATC owners please join!:http://www.3wheelerworld.com/group.php?groupid=27
    Mar 2004
    Gettysburg PA
    498
    I wonder how much it would cost me to have it chromed? I dont want the chrome look. so i guess im gona go with a gloss black maybe. Or what colors do you guys think would look nice?
    My Trikes
    1985 250sx
    1986 250r
