I can take that one easily. It takes me a long time to push my trikes that far.
85 Tri-Z's
85 Quad-Z,
85 YT175 For sale,
83 YTM 225DX,
83 YTM 200L For sale,
82 Tri-Zinger 60 For sale,
8? YTZ 80 Conversion,
85 YT 125,
89 Pro Hauler 230,
05 YFZ 450,
99 V-Star,
i just wanna see you at TF lonesome. I made it last year, was excited I'd ge tot ride with you again and then you didn't make it!
Yeah, we had a string of real dab luck on the way up there. We did not make it past Tennessee. I am hoping to be at my duty station before the up comeing Trike Fest. If so, we will be there with the fleet.
85 Tri-Z's
85 Quad-Z,
85 YT175 For sale,
83 YTM 225DX,
85 YT 125,
89 Pro Hauler 230,
05 YFZ 450,
99 V-Star,
Originally Posted by LonesomeTriZ
Hey Ronnie I know your AKLY'S gonna be in the cooler,,,,,But guess where mines gonna be?![]()
Me too Im going Right for the juguar this time around.....GET IT RAGGGGGG!!!
Thats a sweet lookin carb. Alky Is quite a hassle to run though don't you think![]()
83 ATC 70.
83 Tri zinger
ATC450AF
86 310-R Drag racer
never ran it before jason and im gonna find out, from what i hear.. once it's dialed in look out!!! The pain is gettin it just right!![]()
I hear that If you don't run the engine on gas after the Alky It eats up all the metal parts. You have to run gas through the carb & If you have a aluminum or steel tank you can't leave It In there. I just pulled a 370 stroker 250-R apart & the cylinder was pitted real bad from the after affect's of the alcohol. It's like a 10Hp Increase though. So as long as you purge It out thats the ticket. Should be some good racin, all we need Is a little traction.
83 ATC 70.
83 Tri zinger
ATC450AF
86 310-R Drag racer
ALKY ........ NICE !!!!! be carefull with that mess !!![]()
"07" DR650 Suzuki Dual Sport
from what i heard ya have to run a little gas to lube everything up then run the alky then when your all done ya have to drain the alky and flush with gas so that dont happen, My tank is plastic so i can leave it in there but I'll have to get motion pro portable auxiliary tank for flushing, there like $55.00Originally Posted by Jason Hall
Ya it sounds like a hassel but this bike is just for drag raceing and its all about going fast!![]()
I CAN'T WAIT !!!!
my "RAG" is Running GOOD !!! like ...... almost to BLOW UP GOOD !!!
maybe cause of the Propylene Oxide Additive ???![]()
ha ha ha I was lookin at that stuff! sound like yours is running like i want mine too!
it's ONLY 35 Bucs a Gal. !!! theres a guy in Central Fla. that runs that stuff in his ALKY Suzi 500 .... he say's that the ALKY Runs SOOOO COOL that the Propylene add's "alittle" Bit MORE and Warm's the Motor abit ...
i ran 12oz per Gal .. they said to run 6 oz ... with 10 Sizes BIGGER on the Main
