Results 1 to 13 of 13
Thread: Engine dies when hot
    mark38090's Avatar
    mark38090 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    Hawthorne, Florida
    354
    Question Engine dies when hot
    I have an 85 YTM200ERN, I can ride about 10 minutes and then it shuts off... Acts like it out of gas, but I can let it cool down and it runs fine.
    1984 Honda TRX200
    1985 Yamaha 200ERN ( two of these now)
    1985 Honda 250SX
    1991 Suzuki LT230
    2003 Honda Rancher 350ES
    Aug 2005
    michigan
    125
    try cleaning the engine up and then run some royal purple oil in it
    83 atc 200
    86 lt250r quadracer
    Tionesta, PA
    5,747
    Sounds spark related to me - the next time it "stops running" and is still hot, pull the plug and check it for spark - may be electonic related.
    Sep 2005
    Northwest Ohio(Forest)
    974
    our old 200s did that. we got a new coil and it fixed it
    '86 200x
    Sep 2005
    Lipetsk, Russia
    2,824
    My Panther 440 motor does the same thing, and it's because I haven't changed the coil. Check your electronics.
    I'm back in the USSR...
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Clean the petcock on the gas tank, could have rust in it. I've had that problem several times.
    TF 07,08,09,10,11,12,13,14!
    foster is offline Just Too Addicted Arm chair racerJust too addicted
    Sep 2003
    East Coast Canaduh
    522
    My 185s used to do that, so I ordered a new coil and it never did it again.
    I never actually put the new coil ON it, it's just that as soon as I spent the cash on the new coil, it never did it again.
    No kidding.
    But I'm told the coil will cure it. Good luck.
    Sep 2005
    wisconsin
    475
    Anaheim, CA
    517
    my 200x did the same exact thing and it turned out to be my valves needed adjusting.
    83 250R
    91 CR125R
    Jun 2006
    courtenay bc canada
    4
    ytm
    the oil splash system may not be working
    kando is offline At The Back Of The Pack Arm chair racerFirst time rider
    Saskatchewan
    212
    Also check compression if very low it needs new rings, and hone job. When cylider wall is worn out it doesn't hold any oil in hone pattern and heats up walls stalling motor after awhile when riding it. Let it cool down and it will go till it heats up again.
    1982 YT 125 Yamaha 1984 Honda 200 m
    Apr 2006
    Crestview, Florida
    2,429
    ive seen gas caps that wouldnt vent cause the same problem , but usually its the coil.
    Mar 2005
    ma
    988
    source coil on the stator needs rewinding or replaced. it has a short. ohm out the stator to be sure.
    Billet Triz 250 parts, Case Savers, Engine Mounts, Boost Bottles, Oil Caps, and Shifters, pm me for info
    Shock Rebuilding, PM me for details TRI-Z Shocks rebuilt too
    My Feedback
    http://www.3wheelerworld.com/showthr...k-for-sblt500r
