Wondering what it means when the oil is grey. 85, 250r? Your help is much appreciated.
grey = water
WWW.HREATV.COM
YUP !!!! Mechanical seal...........EXPENSIVE !!!!
"07" DR650 Suzuki Dual Sport
the guy i bought it from said it was normal haha. well dam that sucks. hopefully i can get it fixed soon or find out what he used and why its like that since im not the original owner.
what kind of oil do you use?
Proudly NOT a member of
"Team on the Teat"
Are you using coolant and have to keep refilling it?
1980 110
1982 250R
1985 200s
1985 250R
1985 350X
Parting out...
1983 250R
1984 185s
PM me for parts
Whats expensive? its just a rubber seal isn't it?Originally Posted by Yamahondaman
1980 110
1982 250R
1985 200s
1985 250R
1985 350X
Parting out...
1983 250R
1984 185s
PM me for parts
Step One - Change the oil and take it out and ride it. Step two - check the oil again and see what it looks like. If it looks good, keep riding it and keep an eye on it. They probably drove it through a water crossing or something. If its all gray again, amnd you havent driven through water, you need to replace the coolant pump (impeller) seal. If I remember correctly, on the Honda the impeller and bellows seal are all one unit?
Here are the seals you need to fix it. They are not that bad in price.
http://cgi.ebay.com/ebaymotors/ATC-T...spagenameZWD1V
1980 110
1982 250R
1985 200s
1985 250R
1985 350X
Parting out...
1983 250R
1984 185s
PM me for parts
like said above though, keep an eye on the coolant too. if it keeps dropping you know it's getting into the motor and shouldn't be.
Do like tim said, although, may take up to 3 oil changes to flush out the first batch of water that was/is in there.
Howard
Yeah not expensive but they can be an pain in the arse to get in and outOriginally Posted by crackshot
. After you take the right side of the case off, i had to use a torch to get mine out so don't try and pry it!!! Put the new seal in the freezer and the case in the oven for a min or two then the seal will slide right in!
-Devin
"I have but one lamp by which my feet are guided, and that is the lamp of experience." -Patrick Henry
NEW ENGLAND ATC owners please join!:http://www.3wheelerworld.com/group.php?groupid=27
