Results 1 to 11 of 11
Thread: Oil
    Nov 2005
    arizona
    61
    Oil
    Wondering what it means when the oil is grey. 85, 250r? Your help is much appreciated.
    PA
    3,515
    grey = water
    WWW.HREATV.COM
    Jan 2004
    Palmetto,Florida
    2,300
    YUP !!!! Mechanical seal...........EXPENSIVE !!!!
    "07" DR650 Suzuki Dual Sport
    Nov 2005
    arizona
    61
    the guy i bought it from said it was normal haha. well dam that sucks. hopefully i can get it fixed soon or find out what he used and why its like that since im not the original owner.
    na
    5,702
    what kind of oil do you use?
    Proudly NOT a member of
    "Team on the Teat"
    crackshot's Avatar
    crackshot is offline Worthless, would be a vast improvement. Arm chair racerJust too addicted
    Idaho
    1,024
    Are you using coolant and have to keep refilling it?
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
    crackshot's Avatar
    Idaho
    1,024
    Quote Originally Posted by Yamahondaman
    Whats expensive? its just a rubber seal isn't it?
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
    Rittman, Ohio
    6,276
    Step One - Change the oil and take it out and ride it. Step two - check the oil again and see what it looks like. If it looks good, keep riding it and keep an eye on it. They probably drove it through a water crossing or something. If its all gray again, amnd you havent driven through water, you need to replace the coolant pump (impeller) seal. If I remember correctly, on the Honda the impeller and bellows seal are all one unit?
    crackshot's Avatar
    Idaho
    1,024
    Here are the seals you need to fix it. They are not that bad in price.
    http://cgi.ebay.com/ebaymotors/ATC-T...spagenameZWD1V
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
    Howard's Avatar
    Howard is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Memphis, Tn
    288
    like said above though, keep an eye on the coolant too. if it keeps dropping you know it's getting into the motor and shouldn't be.
    Do like tim said, although, may take up to 3 oil changes to flush out the first batch of water that was/is in there.
    Howard
    May 2005
    Southern NH
    1,489
    Quote Originally Posted by crackshot
    Yeah not expensive but they can be an pain in the arse to get in and out . After you take the right side of the case off, i had to use a torch to get mine out so don't try and pry it!!! Put the new seal in the freezer and the case in the oven for a min or two then the seal will slide right in!
    -Devin
    "I have but one lamp by which my feet are guided, and that is the lamp of experience." -Patrick Henry
    NEW ENGLAND ATC owners please join!:http://www.3wheelerworld.com/group.php?groupid=27
