Thread: Kick starter locked up on my 250 BigRed 85
    svo58 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2004
    clifton park,saratoga county,N.Y.
    166
    I just got my Big Red running and it stalled and the motor sounded like it was wineing.I jumped it and it started it ran for a while then it stalled and now the kick starter is frozen(it will not go down)The kick starter worked fine before i started it,i tried to start it 2 weeks ago then i put a new carb. on it and then it started.Before that i tried to start it a bunch of times with the kick starter and it work fine.Has anyone else had this problem,if so what is wrong with my my motor,could it be the starter. would that freeze up the kick starter.Any help would be great,thanks........svo58
    84 big red 200es with speedo
    84 70cc ATC- new top end ,rear rack, head light and tail light
    85 250es big red
    85 250sx
    springville, PA
    6,185
    just for kicks, check your oil level. We have had pistons seize because of low oil
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Howard's Avatar
    Howard is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Memphis, Tn
    288
    does it turn over with the starter at all?
    Jun 2006
    N.B Canada
    17
    My 86 did the same thing and it was the maine gear behind the kickstart it borke apart eneugh to jam it up.
    Eastern Long Island
    1,688
    Once you figure out what it is if you need any parts let me know. I have 2 good bottom ends in my basement.
    Lots O Trikes!!!!!
    Jul 2004
    166
    The battery is low,i jump start it.It runs then stalls with a wineing sound after it stalls.The kick start is not frozen for now.When it runs it sounds like some thing is rubbing(inguageing) in the motor.Any advice on what is wrong with my motor and how to fix it .Any help on where to start would be great,thanks....svo58
    85 250es big red
    85 250sx
