Get the cover off. Remove the 3 bolts hlding the oil filter cover and remove cover, spring and washer. Remove the small O-ring on the crankshaft. Pry the part of the locknut that is in the depression on the crankshaft. Wedge a penny in the gear to hold the clutch. Remove locknut (Left hand threads!) Remove lockwasher. Slide off the clutch plate. Rotate manual clutch so that the notched part allows the centrifi clutch to come off. If the manual clutch is to come off, wait and use penny to lock it for removal of locknut (after removal of lifter guide and ball bearing. It requires a special tool. Make tool or buy one.
Manual Clutch locknut 29-36 ft-lb, Manual clutch small bolts Guessing 7-10 ft-lb Centrifi/crank 76-83 ft-lb Centrifi clutch small bolts 7-10 ft-lb
Heretahelp...
86 250R
86 250R
86 250R
85 250R
82 250R
86 350X
81 185X
85 250SX
87 200X
Sitting on my can can, doing the pan-o-ram..
