Results 1 to 2 of 2
Thread: Piston Blew
    Apr 2006
    ghettosburg
    43
    Piston Blew
    1985 250R
    Well, basically my piston blew and my engine seized on me. I had been riding it for like an hour. There were little pieces of metal all in the engine and they dented the head and the piston surface. I am my own mechanic and I want to know if I can just replace the piston and rings? Or do i have to replace the piston and rings and bearings? Or do i have to replace the piston and rings, bearings, wristpin, ect... I am going to start ording the parts.
    Oh! Can I wash the reed valve in water? They're all nasty? Can I wash the carburator? It's got a little bit of sand in it.
    Thanks.
    May 2005
    Southern NH
    1,489
    The carb and reed's yes you can wash with water, but make 100% sure they are dry before putting them back on. I would just use brake cleaner on the carb, but the reed's I don't know if they are plastic.....
    You sure the cylinder is fine after all this???? If so then i guess the piston, rings, wristpin and you mine as well replace the bearing while your at at........
    "I have but one lamp by which my feet are guided, and that is the lamp of experience." -Patrick Henry
    NEW ENGLAND ATC owners please join!:http://www.3wheelerworld.com/group.php?groupid=27
