Thread: will a 200E axle work on a 200S
    Sep 2005
    FL
    855
    I am wondering if the axle out of a 200E will work on a 200S. The parts numbers are all most the same(not sure if that matter or not). The 200E number is 42310-958-010 the S is 42310-vm4-000. I was thinkig that since the first parts is the same it may fit. The middle parts of the code is just the model id right? I don't know what the last part of the nuber means. I appericate any help.
    Gabe
    Tionesta, PA
    5,747
    No - the 200S is one of those non-interchangable axles - 200S must be replaced with 200S - nothing else works - not even the ATC200
    Sep 2005
    FL
    855
    OK thank you. I wan't sure. So the first part of the part #s mean nothing when it comes to interchanging?
    Tionesta, PA
    5,747
    I don't think it does - I have seen this scenario with many sprocket setups - I think the first number may just be a Honda Sub-Assembly part - IE - 42310 may just mean rear axle assembly or something like that - check the honda P/N for rear axel bearings and they may very well have those same numbers. This is just an educated guess, but like I said - sprockets from different machines have the same prefixes.
    leroy, new york
    1,025
    i run a atc 200 axle in my 200s i just use the atc 200 sprocket. I think 185s will work, they all use the same bearings.
    burnoutboy's Avatar
    burnoutboy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    New Zealand.
    352
    I run a 200e axle in my Atc 200...
