Thread: How to rebuild Tri-Zinger carb
    I need to rebuild my Tri-zinger carb. Can someone send me a list of parts I need to order to rebuild the carb. I want to get it running this week. thanks,
    Jackson MI
    1,688
    Just take It apart & clean every part you take out. Then put It back together & hope for the best. As long as the jets are not plugged tight you should'nt really need anything but maybe a bowl gasket. I have taken lots of carb's apart & as long as you are carful you can usually use the bowl gasket over again.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    Baltimore, MD
    6,088
    You can still get the trizinger carb parts at the dealership. If I remember right, that is the only place you can get the parts, I don't think anyone offers a kit for the trizinger carb. Don't forget to get your boysen reeds and the DG Nationals pipe for the trizinger. The reeds are the same ones for the pw50.
    illinois
    743
    try bike bandit -oem parts for the view of it clean everything
    take out all the rubber seals and soakit in carb cleaner from auto store
    assemble using the microfiche from bike bandit
    check the floats by assembling it and blow through a long hose attached to the fuel inlet hold the carb upside down while blowing through -there should be no air going through when upside down this is the closed position
    good luck
    Great info
    Thanks for the responses. All your ideas really helped. The choke cable rubber was worn so I ordered a new one. I plan on getting the pipe because I think some of my poor performance was coming from the baffle plugging up.
    Thanks
