Results 1 to 3 of 3
Thread: yt-50
    florida
    2,328
    yt-50
    i have a tri-zinger and im trying to remove the flywheel to replace the stators but im having no luck in removing it any suggestioms
    Apr 2005
    East Texas
    11
    I use a steering wheel puller from any auto parts store. You will have to purchase some long metric bolts the same size as the holes in the flywheel. Also, as with any flywheel or gear, it is a good idea to squirt some PB Blaster on it and rap sharply on the crankshaft nut a few times to help loosen it. DO NOT hit the crankshaft threads directly with the ...make sure the nut is still on and slightly loose. This method works for me regardless of the engine. Hope this helps!
    Life shouldn't be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather, to slide in sideways, thoroughly used up, totally worn out, and loudly shouting...... "WOOOO HAAAA WHAT A RIDE! THANK YOU LORD!!!"
    florida
    2,328
    yea theres a lil problem tho this engine is a yamaha copy im replacing theoriginal yamaha motor with a ans the flywheel has no holes like the yamaha
