Page 2 of 10 FirstFirst 1 2 3 4 ... LastLast
Results 16 to 30 of 149
Thread: Carb Jetting 101: Terms, Tips and Jetting Theory
    Mar 2004
    Eastvale, CA
    630
    Excellent info ! I'd like to add how to do a proper plug chop as I see that question and misinformation all the time. Just remember, plug chops are done to determine main jetting only.
    1. Use a new plug, clean air filter and have your bike, trike or quad warmed up to the proper operating temperature.
    2. Make a WOT pass through at least 5th gear. What's WOT? Go back and re-read 's first post.
    3. Doing all four at the same time, hit the kill switch, let off the throttle, pull in the clutch and roll to a stop. (Rolling out anytime without pulling in the clutch could cause a seizure as the piston will continue at high RPM through it's stroke without pre-mix lubrication and it'll overheat and seize in a hurry. Running out of gas will do the same thing).
    4. Pull the plug and read it. The porcelain insulator should be a nice cocoa brown, not on or near the tip, but down inside the plug. If it's still white or light in color you're running too lean and if it's black and or oily your running too rich. Re-jet, go back to step one and start over.
    Current Ride (Purchased new in Oct. 84) - 1985 Honda ATC 250R w/ ESR 310cc big bore kit
    Wife's Ride - 2009 Polaris RZR 800
    Kid's Rides - 2009 Yamaha Raptor 700, 2008 Yamaha Raptor 250
    Former Rides - 1975 Honda XR 75, 1979 Yamaha IT 175, 1978 Honda ATC 90, 1980 Honda ATC 110
    got sand?
    Pa.'s Highest City
    8,058
    Thumbs up
    Quote Originally Posted by Mr. Sandman
    Thank you!
    I'm having a heck of a time right now trying to figure this out. This was the specific info I needed.
    Aug 2004
    Phoenix
    1,229
    I stumbled upon this page from Duncan racing for Keihin carbs. Has some very useful info. on the needle part of jetting.
    http://www.duncanracing.com/techfaq/...-jetting.phtml
    Remove all the warning label and let nature take its course
    Jul 2004
    Blue Ridge Mountains
    141
    If I might add one suggestion: When tweaking / dialing your carb in, make one change at a time... especially if you don't have much jetting experience. That way, if the change you made has an effect (good or bad), you'll know what and most importantly, you'll know 'why'.
    Great thread!!
    ** '85 Yama- 225DX (wheelie machine)
    ** '85 350X (current project)
    ** '86 TR200 FATCAT (Old Faithful)
    ** '91 KDX250 (The Green Machine)
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    I also would like to add (From personal experience in the last day and a half) if you've got a 2 stroke motor that just will NOT clean out and smokes like a fiend, check your crank seals. Transmission oil level will also more then likely be going down as well too.
    Mar 2005
    Underwood North Dakota Tiger country
    1,055
    OK you carb pro's I have a 500cc with a bing 55 runs great and the plug chops show its jetted correctly It's impossible too kick start with out priming shoot a sqirt of fuel in the carb she starts right up. where Am I going wrong here??? we have just been pull starting it. it takes about 30 feet too get it started
    Trikes currently owned
    E.T. trike 150H.P. and climbing Pure DRAG beast
    85 250r project
    Ontario, Canada
    457
    I have a question too, my base ring doesn't get any color change! it stays looking new...BUT where the threads are gets black and the porcillan does a little too. the ground strap goes half black (maybe alittle less) the other half goes alittle yellow/ gray...the side of the ground strap goes fairly yellow. there is no aluminum specs, nore is the electrode ditch getting filled....the 85 atc 250R runs exellent, maybe alittle too zingy tho (FMF Fatty w/Powercore, BRV and Uni, only mods) running a BR8ES 300ft above sea leval @ 10oC and 40:1 Amsoil synthetic, 91-93 octane
    Jets are: Main 140
    Pilot 52
    Needle 28V
    Air Screw think it was 1 3/8 turns out grr
    i did 4 chops, played witht he screw after 1st, did mental note the turns but well that didn't take lol DAMN!
    I ordered jets and they should b in today or tomorw (142-180)
    Would i be right by saying it needs a 145 or 142 main?
    '85 ATC 250R
    FMF Fatty & Power Core
    Boyesen Rad Valve
    38 PWK A/S
    K&N w/PF (next purchase)
    LSR +4 Axcaliber axle
    LSR Duel row bearing carrier
    DuraBlue Anti-fade (to be installed)
    13/36 sprockets
    '85 ATC 250R
    Parts trike (maybe future build?)
    Phoenix, AZ.
    6,719
    Ttownjoeshow: it's impossible to jet over the internet. All I can say is a 140 main SEEMS like it would be too small for what you're running. Stock is 142 and you're running an aftermarket pipe and filter which should give you substantially better air flow than stock so 90% of the time you would need to jet richer to compensate.
    Dale: Is the plug dry after you try to kickstart it? Might want to try a bigger pilot if it is.
    Mar 2005
    1,055
    the plug looks dry when trying too kick it over I have a larger pilot and will try that thanks
    85 250r project
    Ontario, Canada
    457
    k so i need something cleared up.... By Soot, is that blck or grey?
    Should the ground strap be a 2 tone brown?
    all i'm getting is black on the ring, well on one a light black almost dark brown.
    The ground strap, some black, then closer to the end grey and on one or two sides some yellow
    Thanks a million in advance!
    i got it! soot can b black and grey! ground strap can b brown black and grey!
    now i think black is rich, grey is atad lean and brown is good...
    Jul 2006
    Hot Springs, Arkansas
    58
    2 more cents....
    i've noticed over the years, that when people add multi-stage reeds(thru power reeds, a RAD valve, or ESR valve.etc.).
    They don't follow instructions!
    9 times out of 10, the trike is over-jetted on the main(due to increased air-flow).
    when installing ANY of the above mods, remember to DROP the main jet 1-3 sizes, depending on the plug-chop(its in the instructions).
    On a side-bar........
    I'm not sure, Mr Sandman, but can plug-chops also help to determine correct needle height after the main is jetted in?
    Following plug-chop instructions, but at half throttle.
    Hope any of this helps anybody out there.
    84 250R (sold)
    85 250R 38mm Keihin PJ,Rad valve(w/spacer),
    CR250 head gasket,all DG exhaust ,
    13/37 gearing w/ 22-11x9 wooly booger type treads,
    head re-chambering and +6 swinger by Ronnie,
    stock jug and bottom end,
    112 octane race gas w/ klotz R50 @ 32:1
    Utah
    644
    I am not asking what size jet to run...but trying to trouble shoot my bike and was wondering what size jet others run at my elevation cuz mine is sputterin BIG time.
    (I pulled plug and it looks rich, but bear with me and answer my question) Thanks
    elevation: 5280 feet
    main jet: 142
    idle 'r pilot: 60
    A few wheelers, + an
    '73 Honda 49cc Mini Trail
    '85 200 Big WHEEL
    "Despite the cost of living, its still popular."
    Feb 2007
    Grand Rapids
    34
    How do you raise your needle clip?
    Phoenix, AZ.
    6,719
    Quote Originally Posted by 2sprman2
    It's pretty obvious once you get it apart. Pull the clip off the needle and put it in a different slot (there's typically five positions).
  15. #30
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Well your thread has been very helpfull.
    Thanks
    Eric
