Page 6 of 10 FirstFirst ... 4 5 6 7 8 ... LastLast
Results 76 to 90 of 149
Thread: Carb Jetting 101: Terms, Tips and Jetting Theory
  1. #76
    Billy Golightly's Avatar
    Live Oak, FL
    15,068
    What your turning is more then likely an idle adjuster and not the air screw
  2. #77
    Fresno Ca
    2,695
    Also rember, what are you changeing, most the 4 stroke carbs dont control the air, it controls the fuel, so tighting it up will make it leaner. The 2 stroke carbs are controled by the air. Also some of the 2 stroke carbs you can turn the choke to adjust the idle. screw it in would be lean out would be rich.
  3. #78
    Feb 2008
    Belgium
    63
    Hi,
    Yes my carb is for a 2stroke engine (kxt tecate 86) and I was confused between the air screw and idle adjustment. You are right I must have adjusted the idle screw and not the air screw because this idle is the only screw located on the outside of the carb.
  4. #79
    zoomerman's Avatar
    zoomerman is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Ontario, Canada
    351
    I recently put a 86 carb, power reeds, and dg national pipe and type two silencer on my bike( 83 250r) but haven't started it because of jetting issues. Around what size main jet should i start with? the stock main for the 86 carb was 142 and pilot 50?i was told well it has a 52 pilot jet in it and a 125 for a main jet. The 83 carb comes with a 50 pilot and a 130 main. I would like to start jetting rich like stated, but i don't really have any idea. Should i buy a jet kit and start with a 138 or should i start bigger/smaller? any input would be helpful.
    Thanks,
    Evan
    1985 suzuki alt 185
    1985 honda atc 250sx
    1985 honda atc 200m (all apart)
    1984 honda atc 200es
    1984 honda atc 200x- need motor, plastics, axle, exhaust.
    1984 honda atc 125m- times 2
    1985 honda atc 200m all apart
    1983 honda atc 200e times 2
    1983 honda atc 250r-times 2
    1983 honda atc 200 4 parts
    1983 honda atc 110 times 3
    1979 honda atc 110 smokey
    1978 honda atc 90- restored
    Have lots of extra parts, if interested email at e_mcy@hotmail.com
  5. #80
    Phoenix, AZ.
    6,719
    I'd start with the stock jetting for the 86 R carb. If I remember right it's either 145/42 or 142/45. Can't remember off the top of my head which one of those is right. When in doubt though, go big. Less risk of damage.
  6. #81
    Live Oak, FL
    15,068
    , I made this little guide thing for a plug a member posted in another thread, it might be a nice addition to the first post.
    http://3wheelerworldforums.com/attac...1&d=1209435037
    Edit: Fixed watermark overlap.
  7. #82
    Jan 2005
    Jones, Michigan
    1,821
    http://3wheelerworldforums.com/attac...4&d=1209434047
    pretty cool billy, except the watermark on the bottom right.
    - Chick McGee
    -1985 250sx
    - 1986 atc310R drag bike
    - 1981 110 chopper.
    - 1985/6 350x
    - 2-84 atc250r's and 1 83
    - 2002 trx400ex
    - 1985 atc 250r
    -1985 atc70 WTB PARTS
    - 1985 tecate
  8. #83
    May 2008
    Tenn
    548
    I have a 1983 or 84 YTM 175. I premix the fuel as the oil tank was previously removed. I noticed that the vent tube which come out of the back bottom of the carb bowl is not vented to the crankcase cover next to the right rear wheel but hangs loose. When I hooked it up it filled the tube with gas and I had to take out the 3 screws to drain the casing. Why did it fill up with gas and is it important to have it hooked up there? Could I hook it up elsewhere. One gentleman said he thought it effected the timing if it was unhooked. I know it doesn't need to be filling with gas but don't know its original purpose.
    Thanks for any imput.
    sheeptender
  9. #84
    Phoenix, AZ.
    6,719
    Quote Originally Posted by sheeptender View Post
    sheeptender
    You'd have better luck posting this question in the main area. This thread is specific to jetting which is not part of your problem.
  10. #85
    Nov 2002
    Chezzetcook Nova Scotia
    1,836
    So the ground strap is where to look if you suspect ignition problems, The color on the porcelin inside the plud tells you rich/lean "gas and air" ? What would running a b7es plug in a b8es engine do? I know it is a hotter plug.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
  11. #86
    Ontario, CANADA
    4,538
    Hey guys,
    265 R PV motor, all mods in my sig
    Runs fine first 3 gears then starts cuttin out the last 3.
    Cleans out perfect but has a lil hesitation when you punch it after its been sitting a little bit.
    Lean out my needle?
    Thanks alot
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
  12. #87
    Jan 2005
    RI
    2,530
    Canadaman, i have no idea for you. IS it cutting out lean, or is it rich? What you have in there for jets? The more load on the motor, the more fuel it need...i would think?
    As for a jetting question...Does the needle effect the wide open throttle? Like if you have the needle clip to the bottom, making it rich as possible, will the trike run the same wide open as when the needle clip was all the way at the top, makign it as lean as possible? Or does the needle just effect from low to mid rpms?
    Thanks
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
  13. #88
    Ontario, CANADA
    4,538
    Im going to drop the needle tomorrow and see,
    wheres Doug when you need him!
    #NOLINK
    #SUSPENDTHIS
  14. #89
    Ontario, CANADA
    4,538
    Leaned it out 1 clip and it did the same thing, going to go another clip up tomorrow and see!
    Damn thing
    #NOLINK
    #SUSPENDTHIS
  15. #90
    Phoenix, AZ.
    6,719
    Sorry I was out riding this weekend.
    If you're saying it runs and revs out fine in the first three gears I'd be suspicious of the problem being something else. Electrical or maybe a crank seal. You're not being real clear though. Start with the main jet (see how it runs in all six gears wide open throttle). Get that running clean, then worry about the needle clip, then the pilot/air screw. If you can't get it cleared up with jetting, start testing electrical components. If you still don't have any luck it could be the left crank seal sucking some air.
