Thread: Stainless brake line fitting sizes help
    Solid Snake is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2005
    Lancaster, PA
    316
    The 200x is so close to being complete, the only thing left is a new front brake line. I decided to go with Goodridge brand universal clearcoated stainless line, check it out here:
    http://www.jpcycles.com/productgroup...f-7e0ffb382a18
    Now for these you have to buy banjo bolt adapters like this:
    http://www.jpcycles.com/productgroup...6-29bb9bc083f8
    only I don't know if I need 10mm or 12mm pieces. I know what type of pieces I need and length of hose and everything else, just not what size fittings. Anyone ever build stainless lines and come across this? I should say this will be for the front brake system on an 84 200x. Thanks for all your help.
    Trikes
    1984 Honda 200x, 1984 Honda 200m
    Bikes
    1995 Honda CR125R, 1985 Honda XL100 (gone), 1982 Kawisaki KZ550 LTD,
    2001 Yamaha TT-R 125L, 1983 Honda XL185S (current project), 2001 Suzuki SV650S
    Feb 2003
    California
    623
    If I were to guess I would say 12mm. But I don't know. Are you going to use the straight fitting? I think they come stock with that type of fitting.
    Jan 2004
    Palmetto,Florida
    2,300
    Contact 03Banshee ..AKA..."Nathan" ...He has the part no's to ALL Length's of what you need !!! Stainless Line ANY Length with the End's !!! 12 mm for the Metric Bango Bolt's !!!
    "07" DR650 Suzuki Dual Sport
    Aug 2005
    Lancaster, PA
    316
    Quote Originally Posted by wanta250r
    The caliper connection is a 35 degree bend fitting and the piece at the master cylinder is a straight fitting. The don't come with fittings when you buy the universal lines, so I have to buy the line and two separate fittings.
    Quote Originally Posted by Yamahondaman
    I don't really need the part numbers because I already measured the length I need. Thanks for the sizing for the fittings though, it's greatly appreciated.
    Trikes
    Bikes
    Aug 2005
    Lancaster, PA
    316
    Just a heads up to anyone building stainless brake lines, you need 10mm fittings and bolts for a 200x (83-85 at least). The sizing goes by the internal threads on the caliper's and master cylinder's which is 10mm. Just got mine and put it on, works fantastic and I'm sure it will last practically forever.
    Trikes
    Bikes
